I have to reset the country date time etc every time i turn my camera on, i have tried going through menu and reset but this hasn't solved the problem. Please help
There is a built in battery that can keep the time date etc. info for 20 something hrs. without any other source of power. If your camera has a charged battery, is plugged into an active USB or powered by an adapter and you shut it off and then immediately turn it back on again, what happens? If the clock needs to be reset are you sure that you have completed setting the time. After adjusting all the settings you hit set. Most likely it seems that your internal battery is bad. It should charge when the camera is being powered by the main battery.When you say every time you turn it on I'm not sure what that means. If you turn the camera off and remove the battery for more then 30 hrs. it will have to be reset. If that is the case you need to leave a fully charged battery in long enough to charge the built in battery. If the built in battery is bad you will need to find out if it can be replaced.
