20 Most Recent Casio Exilim EX-Z750 Digital Camera Questions & Answers
Try formatting card on your computer instead. Use a program called 'SDFormat'.
Casio Exilim... | Answered on Mar 14, 2016
This is just the path to the library file, this is where Casio store images automatically.if you want to download photos from sd card while camera is connected keep the camera switched on ,connect cable,go to computer ,the camera should be listed.Then transfer to C:/picture folderYou may need to use an install disc,if you don't then obtain a card reader ,remove card from camera and download across that way.if you need to transfer images off the cameras memory then camera needs to be connected.
Casio Exilim... | Answered on Sep 23, 2014
Delete the photos off the internal memory and remove the battery. this will reset it the factory setting and that should clear it up
Casio Exilim... | Answered on May 13, 2014
I have the same problem starting a few weeks ago when taking pictures out in the cold (-8 Celsius). Viewing the pictures on the computer shows that only a third of the image is being read. The other two thirds are coming out pure white. So when zoomed out it looks overexposed, but it really is missing 2 out of 3 lines.
I haven't found any solutions on the internet. I reloaded firmware 1.02 and tried using the internal memory card to eliminate the removable memory card as a problem.
Any ideas? I love this camera and hate to throw it out.
Casio Exilim... | Answered on Mar 16, 2014
If you are recording the video, you start with the shutter realise button and you stop the scene with the same button. And then again you can start and again stop the next scene with the same button.
Perhaps this looks odd, but you get used to it very soon.
Casio Exilim... | Answered on Feb 11, 2014
FORMAT IT AS NTFS OR RESET UR CAMERA FORMAT
Casio Exilim... | Answered on Apr 28, 2013
If there is an SD for storage your going to want to take the SD card out and there is a little sliding switch. switch that to the opposite side and that should unlock the SD card
Casio Exilim... | Answered on Mar 20, 2013
Try these procedures before sending it out for repair.
Casio Exilim... | Answered on Jan 16, 2013
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Try the procedures in this tip.
Press cursor-down to cycle through the flash modes. See page 64 of this manual.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Follow the instructions beginning on page 169 of this manual.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Casio Exilim EX-Z750 Digital Camera Logo
353 questions posted
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
View Most Popular
Exilim Casio
  • Exilim Casio
Most Popular Question
casio ex z75o only taking 7 photos
  • Cameras
