20 Most Recent Toshiba Satellite A105 Notebook Questions & Answers
for future reference, Disconnect the mouse and plug it back in. It may need a new mousemouse
Toshiba... | Answered on Dec 15, 2018
You can find the manual for Toshiba Satellite A45 on the link mentioned below:
http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su587690/satellite_a40_ug_20031113.pdf
GuruAid.com
Toshiba... | Answered on Nov 26, 2018
I would suggest a factory restore to fix the problem. If you have data on the computer that needs saving then do this first, if unable to do this then take to a computer shop to have it done for you.
Toshiba... | Answered on Nov 14, 2018
Sounds like the ribbon is misplaced, try to place it correctly a few times and see if you can get it to sit right.
Toshiba... | Answered on Oct 25, 2017
Dear beanbean,
This "lovely black screen" is a BIOS password screen. This shows up because somebody has set a boot-up password in the BIOS Setup. If you're lucky, the BIOS Setup is still unprotected, and you can access it as follows:
When you turn it on, look for something that says "Press [button] to enter Setup" or "Press [button] to enter Setup Utilities." Press the corresponding button on your keyboard, and you should enter BIOS Setup.
Now two things can happen. Either you are permitted to access Setup, or you are prompted for the password.
If you can access Setup, navigate to the Security tab and clear all set passwords.If not... then you can either reset BIOS by unplugging the computer, taking off the back, and removing the CMOS Battery (unrecommended), or you can call Toshiba support and ask for the master password (Most manufacturers have a master password, which will allow you to access Setup and remove the boot-up password)
Hope this helps,Ericthecmh
Toshiba... | Answered on Dec 07, 2015
disconnect the cmos battery or reset it with the jumper
Toshiba... | Answered on Sep 23, 2015
That's because some are dual function keys; you've probably hit the 'Alt' or 'Fn' key to the bottom left of the keyboard by accident. If you look carefully at the letter keys, they should have numbers on them in a different colour/smaller text.
Toshiba... | Answered on Apr 05, 2015
1. Open a program called"Camera Assistant." This is a Toshiba-supported computr program designed specifically for people with cameras built into their laptops.You can find this by clicking on the "Start" menu and then navigatingto the "Programs" sub-menu. 2. Press the"Picture" button in the "Camera Assistant" program windowto take a picture using your built-in camera. This will take one stillphotograph for every time you click the button. The image you are taking willappear on the right side of the main program window. 3. Press the"Video" button in the "Camera Asst" program window tobegin recording video using your built-in camera. This will record video untilyou press the "Stop" button. The video you are recording will appearon the right side of the main program window. 4. If you can't open"Camera Assistant," reinstall your drivers. Though the camera on aToshiba laptop is designed to work right out of the box, if it doesn't you mayneed to reinstall the driver that makes it work. Look for the CD labeled"Drivers and Software" that came packaged into the box with yourToshiba laptop. Pop it in your laptop's CD-ROM or DVD-ROM drive and install the"Digital Camera" driver contained on the disc.
Toshiba... | Answered on Mar 18, 2015
turn on, press F2 key to enter Setup. in Setup either cancel password (under Security) or choose Default Settings to cancel the password.
Toshiba... | Answered on Jan 31, 2015
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site. http://www.pelltechnology.com/Toshiba/Laptop/Toshiba-Portables-Satellite-P105-Series-S6024/Toshiba-Satellite-P105-S6024-LCD-Screen-Replacement-P350475.asp
Hope this works!
Toshiba... | Answered on Jan 13, 2015
Tap the restart or turn on the computer, soon as you turn on the computer, tap the f12 button until you get to the pat were it said delete and reboot. And just reboot. That will delete old passwords an delete everything and bring it back to factory default
Toshiba... | Answered on Dec 14, 2014
highlight the item, right click and select copy go to where you want to put the item, right click and select paste.
Toshiba... | Answered on Nov 26, 2014
The space is to improve the bass response. They do not detach.
Toshiba... | Answered on Oct 11, 2014
Lost windows password isn't really a serious problem. I know a fairly easy method to recover lost windows login passwords, only need to create a bootable disk or Usb stick to recover lost windows password, I have made a bootable Disk with the program Windows Password Seeker and reset my administrator password successfully. You can Google windows password seeker or have a look at their website: http://www.passwordseeker.com
Toshiba... | Answered on Aug 12, 2014
Toshiba Satellite A105 Notebook Logo
1,332 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
want instal watsapp asus eeepc 901
  • Computers & Internet
