20 Most Recent SkyScan 86709 Atomic Wall Clock Questions & Answers
2answers
88900 Atomic Clock does not read time and temperature.
Batteries must come out of both the temperature sensor (transmitter) and base (clock and temperature display). Leave out for about 4 minutes. Replace the batteries in the temperature sensor FIRST and set it about 5 - 10 feet away from the base. Replace the batteries in the base and leave them both set without touching any buttons for at least 15 minutes (usually only takes 5 minutes or so). The temperature should start to display. You can set the clock manually to the correct time and have it get the updates via radio in the evening or night. Should work after all this just fine. (have done it alot of times this way over the years)
Good luck.
7/11/2023 7:35:45 PM • SkyScan 86709... • Answered on Jul 11, 2023
How to change day in ajanta odc 70
ASK MAKER FOR THE MANUAL GOOGLE FAILS SO.
3/28/2023 4:09:54 PM • SkyScan 86709... • Answered on Mar 28, 2023
2answers
Sio/Scan Temperature Transmitter 433MHz for batteries
I just changed the batteries yesterday. It was hard to open the battery compartment with bare hands/finders. I used flat screw driver to poke into the notch in the center of the transmitter. Or you can try poke into any **** around the compartment. It works!
7/18/2022 12:58:19 AM • SkyScan 86709... • Answered on Jul 18, 2022
Need help setting the time on the clock it is a
link below will tell you how to set clock. scroll down about half way.
http://www.skyscan.info/content/manuals/15-model-28500.html
3/20/2017 1:07:21 PM • SkyScan 86709... • Answered on Mar 20, 2017
How to adjust settings on skyscan atomic clock
I just fooled around with the settings on the back of the clock and now I think I have it. It may or may not work.
11/2/2016 3:56:26 PM • SkyScan 86709... • Answered on Nov 02, 2016
Clock goes well without pendulum
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling. http://usedclockparts.com/8-clock-movement-repairs/39-how-to-easily-clean-and-or-fix-your-clock-movement
10/3/2016 10:22:50 PM • SkyScan 86709... • Answered on Oct 03, 2016
I scraped the battery acid from battery
You may need to try to repair or replace the quartz movement, this link will help you out. http://usedclockparts.com/14-clocks/clock-videos/126-quartz-battery-operated-clock-movement-repair
10/3/2016 10:18:45 PM • SkyScan 86709... • Answered on Oct 03, 2016
I have model# 88202cop.
10/3/2016 10:13:36 PM • SkyScan 86709... • Answered on Oct 03, 2016
8answers
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers temperature-transmitter-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
4/6/2016 9:20:21 AM • SkyScan 86709... • Answered on Apr 06, 2016
2answers
The outside temp sender won't work. We put new
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
11/4/2015 12:04:23 AM • SkyScan 86709... • Answered on Nov 04, 2015
3answers
Need instructions on 'programming' my Sharp SPC900
I don't know about your atomic sync problem. But here is how you can set the time zone:
Push the Time button once. This will change the Month/Day window to Alarm 1. Push the up button until the desired time zone is reached. Push the Time button twice more to return back to Month/Day display.
8/15/2015 12:24:20 AM • SkyScan 86709... • Answered on Aug 15, 2015
The atomic clock did not reset to daylight savings time. How di I reset it?
Depending on which country you are in (the UK won't reset for a couple of weeks yet), your clock will automatically reset when it receives the adjusted time signal. If your clock is not receiving the signal, try moving it near a window and away from any electrical interference, or it is possible that your battery is getting low and has not got enough power to receive the signal.
3/9/2015 9:58:58 AM • SkyScan 86709... • Answered on Mar 09, 2015
My clock quit picking up the atomic signal, even with new batteries installed.
Try temporarily locating it in a different location until it picks up a signal, usually around a window.
3/4/2015 10:49:42 PM • SkyScan 86709... • Answered on Mar 04, 2015
Change temperature from celcios to farenheght
There should be a button labeled "C/F" to change the temperature. I don't own that brand, so I'm not sure if it's on the transmitter or on the receiver unit. Here is a link to the owners manual: Model 86709 SkyScan Atomic Clocks
10/28/2014 1:42:44 AM • SkyScan 86709... • Answered on Oct 28, 2014
SkyScan 86709 Atomic Wall Clock Logo
271 questions posted
Top SkyScan Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
View Most Popular
SkyScan Home
  • SkyScan Home
Most Popular Question
temperature transmitter
  • Home
