20 Most Recent Emerson Smartset Clock Radio Questions & Answers
read your instruction manual .usually have to use 2 buttons at the same time .
Emerson Smartset... | Answered on Nov 06, 2017
Try Googling (emerson)(CKS 1855)(manual) without parens for instructions.
Emerson Smartset... | Answered on Sep 01, 2017
[http://www.emersonradio.com/owners/SmartSet%20Series/] copy this web link and paste it into the address bar of your web browser. It will take you to the Emerson customer support web page for the SmartSet Clock/Radio owners manuals.These manuals are in pdf form, so you will need a pdf reader to read the manual.You will also need a pdf writer to make a copy of the manual for yourself. Once there locate your make and model of Clock/Radio and open the link. You can make a copy of the owners manual using the print function of your computer to make a pdf copy. I hope this information help you with your problem of finding a owners manual for your Clock/Radio. Thank you for using FixYa and have a nice day.
Emerson Smartset... | Answered on Jul 11, 2017
You can get the manual on the link below. Please alow time to load large file.
http://www.emersonradio.com/owners/SmartSet%20Series/CKS3528_110606.pdf
Good Luck and please rate 4 thumbs up for the free answer
Emerson Smartset... | Answered on Apr 13, 2017
Make sure of the model.
Bulb Replacement The flashlight in this unit use LEDs (Light Emitting Diodes) instead of incandescent bulbs. These LEDs should last for the full useable life of the product and they are not consumer replaceable. There are no user serviceable parts inside this radio. Please refer all service problems to a qualified service facility
http://www.emersonradio.com/resources/owner_manuals/manual_1312918603.pdf
Emerson Smartset... | Answered on Sep 17, 2016
Jot down your model number.
Manuals for all Emerson products are available at http://www.emersonradio.com/owner_manuals.php Simply select your model in the drop-down menu and you're set.
Emerson Smartset... | Answered on Apr 22, 2016
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
Emerson Smartset... | Answered on Nov 29, 2015
i think you might have to change the time
Emerson Smartset... | Answered on Nov 21, 2015
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
Emerson Smartset... | Answered on Oct 09, 2015
Sorry it took so long to give you a answer to your problem. I hope this information help you with the problem. Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Emerson Smartset... | Answered on Jul 26, 2015
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
Emerson Smartset... | Answered on Jan 13, 2015
Emerson Smartset Clock Radio Logo
433 questions posted
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Audio Players & Recorders
Most Popular Question
replace light bulb in emerson projector
  • Audio Players & Recorders
