Maybe you should read the user's manual? I've reas cutomer's review at Amazon and looks users have no problem with the scanning feature of this printer. If you don't have the manual, get it from here: Canon PIXMA MG2520 Manual
Maybe these videos should give you some more info:
Make
sure that the machine is turned on, lift the Scanning Unit (Printer
Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
Note: - Do not attempt to reattach the protective tape once you have removed it. - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
*One
black cartridge and one color cartridge must be installed in the
machine in order for the printer to operate. It does not matter if the
capacities (Standard or High) do not match.
Push
up on the front of the cartridge until it locks into place. (A click
sound will be heard when the cartridge is locked in place.)
Confirm that the ink cartridges are installed properly.
<1> The ink cartridge is not installed properly.
<2> The ink cartridge is installed properly.
Fold the scanning unit support and close the scanning unit (printer cover).
Wait until the preparatory operation is complete; it takes about one to two minutes.
primeramente me salio 5100 pero luego paso a 6000 no se lo que puede pasar ya que no se mueven los cartuchos y no hace el reseteo cuando la enciendo y solamente me sale COMPRUEBE IMPRESORA Y SALE 6000 ERROR.
en espera me sean indicados los problemas que se puedan subsanar un saludfo
