20 Most Recent
Canon Ink Cartridge for Pixma MP252 Questions & Answers
Spilled milk Cleaned it up but now when I try to print paper goes in crooked and jams -
Examine the paper guides looking a any paper jam and remove.
Paper jams are sometimes difficult to remove without disassembling
the printer.
However you could try using card stock as it is firmer and may push the paper jam from the printer, if this fails call one of your computer literate family or friends to help. As most printers are not to expensive, I will not suggest any repair shops. The cost of a printer is in most cases less than the the cost of the replacement ink cartridges.
6/19/2016 10:20:58 PM •
Canon Ink...
Answered
on Jun 19, 2016
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the Home Click Here to SearchMG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are IncorrectWhen Printing Becomes Faint or Colors Are IncorrectMaintenance ProcedurePrinting the Nozzle Check PatternExamining the Nozzle Check PatternCleaning the Print HeadCleaning the Print Head DeeplyAligning the Print HeadPage toperror light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
11/15/2015 6:25:18 AM •
Canon Ink...
Answered
on Nov 15, 2015
Error code B200
Typically this means a foreign object inside. Check for crumpled ink soaked paper inside at both ends of the print head path, then check for paper fragments in the cleaning station. The other thing to check is the thin plastic strip running along the back of the print head is clean.
12/22/2014 7:56:33 PM •
Canon Ink...
Answered
on Dec 22, 2014
Does this printer scanner scan to save to the computer and if it does how do I do that.
What OS are you using? How is the all-in-one connected to your computer. To scan to the computer, you need to install the full software package (if it is available for your OS). If only the OS drivers are available, you will be able to save scans. However, you can only initiate the scan from your computer. Additionally, if you have the all-in-one connected to a print server (or router USB port), the scan features will not work. (The scanner requires two-way communication with the computer and can fail if you use a USB hub, bad cable, or a long cable. Thus try a new cable of less than 6' in length if you can't launch a scan from the computer.)
Next: use the Canon software (MP Navigator EX) and initiate a scan. You will need to adjust some settings to make sure that the program knows what program to open when you press the scan to computer button. The monitoring software will need to be running to identify the button presses. To set this, select Preferences, then the Scanner Button settings tab. Select Actions and then choose Save to PC in the Event drop-down menu. Use the first scan to set the default scan preferences and destination folder. Then click OK to save the settings.
If you do not have the MP Navigator program, use any scanning program on your computer. For Windows 7 and 8, there is Windows Fax and Scan that can work with the MP252. The Apple Macintosh has a similar program. Third party software will also work (Nuance's PaperPort, for example).
See page 318 in the Advanced section of the manual (available from Canon) for screen captures of setting MP Navigator.
http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/PIXMA_MP252.aspx?type=manuals .
I hope this helps.
11/6/2014 4:44:14 AM •
Canon Ink...
Answered
on Nov 06, 2014
Scanner canon dr6030 cants pull the paper
Troubleshoot this issue step by step:
Check the Feed Selection Lever:
Ensure that the Feed Selection Lever (located on the lower left side of the front of the scanner) is in the correct position (up) for separation.
Straighten the edges of the stack of documents to be scanned.
Set the document guides so they are wider than the document to be scanned.
Place the documents face up into the feed tray, ensuring they touch the document stoppers.
Clear Any Jammed Paper:
Be careful when removing jammed paper to avoid cuts.
Remove any documents that have been left in the eject tray.
Close the document eject tray.
If the document ejection is stopped partway, perform this operation with the document eject tray extension open.
Hold the upper unit as shown in the diagram and open it to the point where you can remove the jammed document. The pickup roller is located in the middle of the upper unit. Do not hold the protrusion on the upper unit when opening it, as it may deform the pickup roller or cause a feeding error.
Close the feeder cover.
If the jam occurred in the feed section, pull the document out carefully without applying too much force. Be sure to remove any torn parts remaining in the scanner.
Close the upper unit slowly, ensuring it clicks into place. Do not force it to close, as this may damage the scanner.
After removing the jammed paper, check if the last page was scanned, and then continue scanning.
Rapid Recover System:
If a paper jam occurs when the "Rapid Recover System" is enabled in the ISIS/TWAIN driver settings, the image of the document is not saved, and scanning stops. You can continue scanning from the document that caused the paper jam after fixing the issue.
Additional Considerations:
Make sure the pickup rollers retract when the machine is powered on.
Check that the stopper plates are in the down position.
Verify that the upper unit is completely closed after clearing the jam.
Remember to handle the scanner components carefully to avoid damage. If the issue persists, consider seeking professional assistance or contacting Canon support for further guidance
