Model GLTF2940FS02.
Hey friend, thank you for your post!
From my understanding you are receiving an error code of "E90" on your Frigidaire washer. I am showing that as an invalid error code. It might be a miscommunication with your control panel and I would suggest performing a reset on your washer. In order to reset the washer you would need to disconnect the power from it for roughly ten minutes. If you continue to receive an error code of "E90" I would suggest contacting a professional technician for proper diagnosis and repair. Hope this is helpful. -Matt
SOURCE: E90 Error Code
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
SOURCE: error code E90
Remove the front panel and on the right side at the bottom youll find the main Circuit board.There is a connector on the harness that needs to be making a tighter contact.Make sure that all the wires that are in contact with the circuit board are firmly touching.Sometimes using a pair if pointed tweezers and a sewing needle will be all you need to fix this .There is hope so dont go out and replace any parts just yet. .
SOURCE: washing machine displaying E90 error
SOURCE: hi zanussi fjr 1254 w error code e90 what does
This error code seems to be the control board detecting a wrong
configuration (in other words, an illogical set of sensing conditions,
from its connected sensors and wiring). It apparently can happen, when
wires become badly contacting, or if contaminated with motor brush
carbon (the horrible black powder that comes off the motor commutator
and brushes), or corroded from other contaminants from the soap
dispenser area. You should be able to check this, remove, clean and
replace the contacts:
Thanks
SOURCE: what does error code e90 mean
Error code 90 means it could be a communication error between the main interface and the main P.C.B. (PROGRAMMER).E90 can cover a few faults it could mean that the main board is damaged.have you had any power failures recently.If you are confident to have a look at the fault make sure that the main power is off. Remove the top lid there are 2 screws at the rear of the underside of the lid then check all the connections on the main board and the display board if possible remove any plugs you can get to easily and replace because it may just be a bad connection.Try this and then power up the machine and just try it on spin if no error codes come up then try it again.If this is not successful it would be too costly to repair.
