20 Most Recent Zanussi FJS1225W Front Load Washer Questions & Answers
2answers
My zanussi's door wont lock
Front PCB faulty, if you remove pcb you may be able to resolder blown track on pcb totherwise it will require replacement.common problem with this model. Regards Advisor
1/16/2023 8:09:31 AM • Zanussi FJS1225W... • Answered on Jan 16, 2023
The washing machine recently will
Hello! Most probably the carbon brushes from the motor are worn out.
2/26/2018 11:34:57 AM • Zanussi FJS1225W... • Answered on Feb 26, 2018
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
10/23/2016 12:43:06 PM • Zanussi FJS1225W... • Answered on Oct 23, 2016
0answers
I think the drive belt has gone as the motor sounds as if it is spinning but the drum isnt moving. How easy is it to fit a new drive belt?
I haven't worked on a Zanussi yet but usually once the top has been removed replacing the belt is a fairly straightforward and intuitive process - it is removing the top that tends to be the difficult part. I expect washer-driers would be more difficult but so far I have managed to avoid those.
3/16/2016 8:16:26 AM • Zanussi FJS1225W... • Answered on Mar 16, 2016
E34 code what does this mean
Incongruence between level of electronic pressure switch and level of anti-boiling pressure switch 2 (duration of fault at least 60 seconds). Cycle is blocked with door closed. Could be: Hydraulic circuit of pressure switches; electronic pressure switch; pressure switch; wiring between main PCB and electronic pressure switch; wiring between main PCB and safety pressure switch; and finally main PCB. Dado
12/16/2015 9:10:43 AM • Zanussi FJS1225W... • Answered on Dec 16, 2015
My machine wont spin it fills up and drains but
Don't know how to use dryer mode on my washer dryer.
3/23/2015 9:58:20 PM • Zanussi FJS1225W... • Answered on Mar 23, 2015
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
3/10/2015 8:19:52 PM • Zanussi FJS1225W... • Answered on Mar 10, 2015
2answers
Just the power light comes on
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
8/14/2014 1:31:19 PM • Zanussi FJS1225W... • Answered on Aug 14, 2014
Zanussi FJS1225W Front Load Washer Logo
421 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
think drive belt gone as motor sounds as
  • Washing Machines
