20 Most Recent Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Questions & Answers
Thank you for your inquiry, friend!
I see that you are having trouble with your Frigidaire washer not starting. This sounds like a possible problem with your control panel or keypad. You may need to disassemble the washer in order to pinpoint the possible problem this is not a simple DIY job. I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid future issues as well as possible multiple part purchases. I hope this information is helpful. -Matt
Frigidaire... | Answered on Apr 22, 2015
CHECK MOISTER SENSOR AND OR THERMISTOR. THERMAL CUT OFF AND CYCLING AND HI LIMIT THERMOSTATS
Frigidaire... | Answered on Apr 01, 2015
The Frigidaire GLTF1240A clothes washer has a tub capacity of 2.65 cubic feet. Under typical conditions, based on a yearly average of 392 loads of laundry, the Frigidaire GLTF1240A is estimated to use 341 kilowatts of energy per year. Obviously, this number will vary depending on things like the size of loads that you wash, and temperature at which you wash your clothes. Also, this figure is calculated according to a test done by the US Department of Energy which takes into account the energy consumed by the washer as well as the energy needed to heat the water with an electric water heater. If you use a gas water heater you will probably use fewer kilowatt hours but you will consume gas to heat the water.
Its estimated water use is 9,806 of gallons per year. It is estimated to use 9.4 gallons per cycle, per cubic foot of tub volume. You can use this "per cycle, per cubic foot" to compare washers against each other. The lower the number, the more efficiently the washing machine uses water, assuming your clothes are equally clean after being washed in either washing machine.
Frigidaire... | Answered on Apr 16, 2019
Make sure you are closing door properly and not slamming it the latch assembly tends to be sensitive at times, try selecting and then cancel
Frigidaire... | Answered on Apr 01, 2019
You may have a problem with the water pump remember that all these components are relying on each other to function properly try searspartsdirect.com for any info you need
It could be a mechanical problem. Check that the door seal is not swollen or bulged. Is the door latch tight when you close the door? Check the door latch lever for alignment and wear.
http://www.fixya.com/tags/clothes_stuck_agitator_washing_machine/browse/frigidaire
To prevent clothing from knotting and twisting:
  1. Avoid mixing heavy items with light items.
  2. Avoid putting too many or too few items in the washer.
  3. Make sure you set the proper water level for the size load you are doing. ...
  4. Never wrap the clothes around the agitator. ...
  5. Be sure your wash water is not too hot for the fabric
Frigidaire... | Answered on Mar 06, 2019
check the cold water solenoid is allowing water into the machine,this can happen even when the machine is not in use
Frigidaire... | Answered on Feb 28, 2019
Incredible that customer support would not have that basic information. You might have success by contacting a selling organization, thereby establishing the missing link between sales and support.
Frigidaire... | Answered on Feb 25, 2019
Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Logo
9 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
washer start
  • Washing Machines
