20 Most Recent Zanussi ZWF1430W Front Load Washer Questions & Answers
How to recover credit card from zanussi zw171201wa integrated washing machine
I'm sorry, but I'm not sure I understand your question. Could you please clarify what you mean by "recover credit card from zanussi zw171201wa integrated washing machine"? Credit cards are typically used for making purchases or payments, and I'm not sure how they would be related to a washing machine. If you are having trouble with your Zanussi washing machine and need assistance, I recommend referring to the user manual or contacting the manufacturer's customer support for troubleshooting guidance. They may also be able to provide instructions for retrieving any lost items from the machine.
3/14/2023 11:00:52 AM • Zanussi ZWF1430W... • Answered on Mar 14, 2023
2answers
E30 error message what does it mean, Cheers,
E30 can be a faulty pressure switch,Heating element earth fault or the main P.C.B.(Programmer).Does the machine fill with water then empty.
Most common fault is the heating element,once this is replaced it should cure the fault.
5/19/2019 3:18:36 AM • Zanussi ZWF1430W... • Answered on May 19, 2019
Error code e70 what does it mean
NTC sensor faulty or badly positioned.Could be: NTC sensor badly positioned; NTC sensor faulty; wiring faulty; PCB faulty.Dado
7/6/2016 8:37:19 PM • Zanussi ZWF1430W... • Answered on Jul 06, 2016
2answers
Error Code E90
it seems to be a common error code on some Zanussi models. This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts: Take the top off the machine, (ENSURE IT IS UNPLUGGED) and on the right hand side of the machine, you should see a set of 4 blue wires that go from the electronics module to the front display unit. Take this plug off (it is held on by plastic retainers) clean with wd40, or silicone (Servisol) contact cleaner, then dry, replace, then try again. If it is very badly corroded or pitted, you may have to replace that part of the wiring and socket.
If it is not that, then the wiring to/from various other sensors could be damaged, or the control board could be faulty. It is probably worth checking around other plugs and sockets, re-seating each one in turn, that lead to the control board, as they are expensive (£60 - £80). Pulling off and plugging back on (Re-seating) the plugs and sockets has the effect of cleaning the contacts, and may fix certain intermittent faults like this. Obviously check for any plugs/sockets that appear burnt, corroded, or discoloured compared with the others, and clean the contacts with emery or a needle file.hope this helps pls do let me know
3/22/2016 10:53:37 AM • Zanussi ZWF1430W... • Answered on Mar 22, 2016
Whats a E70 code mean on my washing machine when i switch it on , it seems to still work ok
E70 indicates a fault in the heating circuit
3/16/2016 4:12:59 PM • Zanussi ZWF1430W... • Answered on Mar 16, 2016
Turns on. Fills with water, then why does it display error code e60?
Someone posted a list of codes: Error code e60 zwg 1140m Some people say they just pressed and held the reset button for 5 seconds.
11/27/2015 9:11:13 AM • Zanussi ZWF1430W... • Answered on Nov 27, 2015
4answers
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
7/1/2015 2:06:54 PM • Zanussi ZWF1430W... • Answered on Jul 01, 2015
2answers
Zanussi washing machine ZWF 14581 error code 43 is
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
6/14/2015 5:30:06 AM • Zanussi ZWF1430W... • Answered on Jun 14, 2015
Stops when it gets to rinse/spin part of cycle
check pump for blockage
4/13/2015 7:25:47 PM • Zanussi ZWF1430W... • Answered on Apr 13, 2015
Fabric softener drawer water residue after washer completed cycle
This is probably due to a build up of residue of softener. Remove the drawer, strip the bits off, and clean with a toothbrush. Then replace, and this should solve the problem.
4/12/2015 2:55:33 PM • Zanussi ZWF1430W... • Answered on Apr 12, 2015
Conditioner not being used
you need to check your water valve this link will take you toon zanussi tutorials How to replace Zanussi washing machine door seal
2/11/2015 10:41:36 AM • Zanussi ZWF1430W... • Answered on Feb 11, 2015
Cannot fit door seal l have tried but the spring will not sit inside
Judith, these things are a bi**ch to fit. You need 3 hands and patience by the bucket load. Try a good DIY neighbour or lastly an appliance engineer. Its all about experience and having the knack to fit one. Sorry.
12/5/2014 1:13:43 PM • Zanussi ZWF1430W... • Answered on Dec 05, 2014
2answers
Zanussi zwf 1221 will not turn drum, the end light
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
9/9/2014 3:36:18 PM • Zanussi ZWF1430W... • Answered on Sep 09, 2014
Zanussi ZWF1430W Front Load Washer Logo
336 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
cannot fit door seal l tried but spring
  • Washing Machines
