Canon MP610 Photo All-In-One Printer Logo
A
Anonymous Posted on Feb 15, 2015
How do I scan from the Canon MP610? When I put doc on glass and press scan and ok, it says to connect to the usb cable and turn on pc. My computer is on (it's a laptop.)
Put doc on glass and pressed scan and ok.
sahoo_sanjay
Level 3:
Master:
  • Canon Master 553 Answers
  • Posted on Feb 15, 2015
sahoo_sanjay
Canon Master
Level 3:
Master:
Answers
553
Questions
0
Helped
219081
Points
1676
Dear
three defects may cause.
1- change usb cable to different port. (test the port of pc with using pen drive)
2-do replace with another USB cable.
3- printer may defect.
remedies- Try to un install and reinstall the printer driver and its software.
Besides these trained personnel required.
Thanks.
How do I scan to my Toshiba laptop. It tells me I am not hooked up to my computer. I can send docs to printer but do not know how to use the scanner.
First how is the computer connected to the printer (USB or wireless)? Next did you install the full software for the printer or just the basic driver? The software is available from http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx472#DriversAndSoftware . What OS are you using? What firewall software do you have installed?
First, if you are using a USB cable, try a new cable of less than 6' in length.Try a different USB port and a direct connection if you use a USB hub. Scanning requires bi-directional communication between the computer and the MX472. Printing doesn't need the same level of two-way communication.
For a wireless connection, you'll need to ensure that your firewall allows for the bi-directional communication on all of the relevant ports.
Next launch the IJ Scan Utility software. This is how the Canon all-in-one talks to the computer. Put your document/picture on the scanner glass face down. Select the Scan from Computer tab; it's the first tab. Try scanning manually after setting the desired scan software, scan DPI and destination. See http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx472?pageKeyCode=ekbresults&CONFIGURATION=1011&PARTITION_ID=1&secureFlag=false&mType=PIXMA%20MX&mName=PIXMA%20MX472&TIMEZONE_OFFSET=&USERTYPE=1&CMD=VIEW_ARTICLE&ARTICLE_ID=53332 for some details on these settings. This manual scan will work with any connection type between the computer and the printer, if the ports are not blocked by a firewall.
If you wish to use the Scan from the Operation Panel option, you need to have a USB connection between the computer and the MX472. You also can't set this from the Image Garden software if you launch that first. After doing your first manual scan and getting the initial settings, select the Scan from Operation Panel tab. Set the Auto-Scan options as per your initial scan settings. Click OK to save the settings. Now, try launching the scan from the LCD panel or Scan button on the all-in-one.
I hope this helps. If you are using a network connection, please add a comment with the firewall software for details on how to allow the scanner to communicate to the computer.
Whenever i try to print anything my printer prints the first 5 lines or so and then just stops and moves on to the next page where it print the first 5 lines before giving up again.
What type of document are you trying to print(PDF, MS Word doc, etc)?
Is the printer connected via USB cable, Bluetooth?
First thing I would do is try printing a different document or even a different type of document.
If printing different documents results in the same problem then I would uninstall the current drivers, download the latest drivers from Canon, then install those drivers and try printing again.
Also, if the printer is connected to your computer via USB cable verify the cable has no exposed wiring or try a different USB cable.
7helpful
I am trying to scan a doc on my canon MP272 and just get the numbers : 1, then E then 3. What's that mean?
According to the manual, the error code E, 3, 1 (cycles) means that the printer is not connected to a computer with a USB cable. If you have a cable connected, remove and reseat it, or try a different USB port on the computer.
If you're trying to scan, you need to be able to send the scanned image to a computer. If you're trying to copy, press the Black button for black/white copies or the Color button for color copies.
1helpful
Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
2helpful
When connected to Airport Express via USB, it will
Airport Express provides only a print server, not a networked usb hub so it can only print. I'm afraid you'll have to go back to wired for scanning.
1helpful
How do i scan a document?
Place photo on glass platen, then got to START
Start button, Canon Utilities, Solution Menu, Scan/import, photo/platen, then press big green button.
THen have fun scanning it is fantastic
8helpful
2answers
Problem using OCR with Canon MP610 all-in-one
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
2helpful
3answers
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
1helpful
I can't scan anything from my MP 460
had probs with scanning at first
1.put doc in scanner
2.push scan
3.choose color or black
4.press scan again
thats what i did works ok
old marine
old marine
ZJ Limited
ZJ Limited
