A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
Here's the definitive reset procedure
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
please rate my answer after trying if satisfied
Check the AC power for the machine.The power should be 120VAC +-10%. Make sure it has its own dedicated power and not sharing power with any other device. If the power checks to be good, follow the steps below.
Perfrom a Printer Reset. A Printer Reset can be done by:
1. Enter Service Mode by pressing the ADDITIONAL FUNCTIONS key, then the # key.
2. Scroll through the menu using the arrow keys to the left or right of the SET key.
3. Find #7PRINTER and press the SET key.
4. While in the the #7 PRINTER menu, use the arrow keys and find #4PRINTER RESET and press thre SET key.
5. A selection of either YES or NO will appear, use the arrow key to the LEFT of the Set key to select YES.
6. After YES has been properly selected, unplug the machine and plug it back in.
Following these steps can reset this code
SOURCE: Image Runner 210S
it is a fuser problem:-you have to check-.
1-low temprature due to blown lamp(change it).
2-thermal switch(reset it)by pressing on it.
3-ac driver problem(heater control board.
SOURCE: Cannon Copier image Runner 400/330 series error 051
error 805 on iR 400 and trouble on power suply
