SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Testimonial: "how to fixing the ir 400 web roller "
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
SOURCE: Canon IR 3180C. Error code E000008-0001.Enter mode
click this link to find the service mode procedure
and here is the service manual:
http://www.4shared.com/file/P_7SU82j/ir3100c-smpart1.html
http://www.4shared.com/file/6X_eK9Cx/ir3100c-smpart2.html
