20 Most Recent Canon imageRUNNER 400S Copier Questions & Answers
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
Canon... | Answered on Jul 22, 2019
sir my machine gp 405 showing the above error 0100, 301, 220
what the reason and solutions. please give me
Canon... | Answered on Mar 26, 2019
Hello Glenda
I believe I can help you as I am prepared to send the entire users manual to in a PDF format if this is ok. I specifically found the remove used toner and add new toner section but I believe you may benifit from thr entire manual. Although I am new to this "FIXYA" forum I am a 20 year veteran toner boy(lol) so I am sure I can help. Just respond to "FIXYA" with a favorable comment and let me know how you wish me to respond. I see your E-Mail address and can send it that way which seems the most effective way. Glad to help, happy New Year. P.S. even if ya dont say happy things about my I help I will gladly help, I was just hoping 4 an atta boy from them! :-) Take care.
Canon... | Answered on Dec 01, 2018
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity
Canon... | Answered on Oct 12, 2018
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Canon... | Answered on Sep 05, 2018
its because of composit power supply(hvps) replace it...........
Canon... | Answered on Sep 03, 2018
hi. there is a problem with the hard drive unit and need to be replaced .
Canon... | Answered on Jul 24, 2018
e100
Canon... | Answered on Jul 05, 2018
i have ir400 machine but not touch the sharpnees button
Canon... | Answered on Jun 13, 2018
it's formatting possible in few city only in india like MUMBAI - DELHI - INDORE etc. because it's not a common or general format process. Try nearest used copier dealer.
Canon... | Answered on Apr 27, 2018
my cannon ir400 xerox machine is on but no working power supply is full but not run machine
Canon... | Answered on Feb 22, 2018
when i start copy Error E100 occurs. How do i solve this problem please immediately send me the manual of canon 405 and immediately send me solution of this problem.
Canon... | Answered on Jan 25, 2018
check the cooling fan motor may be one of the fan is not rotating
Canon... | Answered on Oct 15, 2017
Order of Turning On/Off the Machines
(host machine + accessories)
If a delivery accessory (e.g., finisher) is installed,
be sure to respect the following order when turning
them on/off:
<Turning On the Power>
1. high-capacity stacker, finisher (either)
2. professional puncher (non-Japanese model
only)
3. host machine
<Turning Off the Power>
1. host machine
2. high-capacity stacker, finisher (either)
3. professional puncher (non-Japanese only)
- Failure to observe the order of turning on the
machines prevents the host machine from
recognizing the accessories.
- Failure to observe the order of turning off the
machines will lead to an error ('E730' or
'E503').
Canon... | Answered on Oct 10, 2017
it printer board err
Canon... | Answered on Sep 17, 2017
The error code E604 means that your hard drive is failing or it has failed. You will have to replace the hard drive and have it flashed with the software to run the copier.
Canon... | Answered on Sep 14, 2017
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Canon... | Answered on Sep 07, 2017
912 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon copier model ir 400s shows error
  • Office Equipment & Supplies
