20 Most Recent Canon imageRUNNER 2270 Copier Questions & Answers
Hi, does stripes appears only on copies or also on printed images?
If only on copies that means that you have to clean the copy glass.
If on both, its probably drum unit that causes the problem. Usually the stripes are slim, and verry close to each other, like a sharp brush paint job.
How many copies do you have with these drum? check it on 123 button.
If the copie is on one side totally black and the toner isnt fixed on paper that means that you have to replace fixing film.
For service manual write me on emma.servis@gmail.com.
Hope that helped!
Canon... | Answered on Mar 02, 2015
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR.
Canon... | Answered on Jan 26, 2015
Small torn paper was left on your fixing unit. You can remove the fixing unit look for that small piece of paper. ;)
Canon... | Answered on Jan 14, 2015
there might be something jammed in it like paper so check all the compartments or the ink section if thats not hte case then get it checked out by a professnial
Canon... | Answered on Jan 06, 2015
check your drum volume and make sure not exceeded lifespan, clean up your scanner unit or replace your developing spacers and bearings,maybe also your developing cylinder.
Canon... | Answered on May 16, 2014
check line voltage
Canon... | Answered on Apr 30, 2014
fixing film assembly
Canon... | Answered on Feb 17, 2014
problem from laser unit
Canon imageRUNNER 2270 Copier Logo
126 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
error e000002 0000 canon ir2270
  • Office Equipment & Supplies
