Kingston DT101G2/32GB 32GB DataTtraveler 101 G2 USB 2.0 Flash Drive DT101G2/32GB Logo
A
Anonymous Posted on Jun 13, 2014
HOW TO FIX THE I/O OF FLASH DRIVE - Kingston DT101G2/32GB 32GB DataTtraveler 101 G2 USB 2.0 Flash Drive DT101G2/32GB
How can i fix a syntex error on a flash drive without downloading anything
it happened since you remove your flash drive without using the "safely remove hardware" tray icon then your the master boo trecord of your flash drive became corrupted.You can try this:at the command prompt type chkdsk X: /f /r where X is flash drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
I have 2 .0 GB pendrive same is not formatted
If the flash drive can not be formatted, there are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support.
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps.
Read-only files and how to them?
Possibility
Firmware flash drive corrupted (the disk is write protected).
Solution
To repair damage to the firmware, the solution can be found on google seach engines. Example; Fix transcend flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
4gb sony pen drive do not format
Flash drive can not be formatted, there are two possible
To fix Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
Not open the memory card the computerslove probleam
If the flash drive is detected but error, there has been damage to the partition table or firmware. But, if the flash drive is not detected, there has been a hardware damage.
Solutions, flash drive detected but error
To fix the SanDisk flash drive, use the U3 LaunchPad software. This software can be used to saved data, repair the firmware and update the firmware.
For Win Xp, download from here SanDisk Support
To Win 7, download from here SanDisk Support
Solutions, flash drive not detected
Chances are, there has been cracked solder. To fix this, open the flash drive casing, use a soldering iron to heat the solder component flash drive.
Hope it helps
2answers
Transcend Jf V30/ 32 gb flash drive. When saving data less than 4GB and after removal of flash drive most data are lost. What can I do ?
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
1helpful
How can i fix my kingston dt101 2gb flash drive
The OS format tool will not format flash driveswhat you need is this one
http://en.kioskea.net/download/start/download-127-hp-usb-disk-storage-format-tool
Although it was produced by HP it works on any,
Unrecognized Flash Drive
Check out if the USB ports are 1.1 or 2.0
Your computer may use 1.1 and not see the newer 2.0
3helpful
Flash locked by lockv116.exe
how to solve problem (how to fix locked flash drive because of LOCKv116.exe )
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
