20 Most Recent Kingston (DTIU3/2GB) 2 GB USB Hard Drive Questions & Answers
You can follow the below commands
got to run
type cmd and press enter
then formatdrive name: and press enter
then it will ask for yes or no
press y
again do the above step once again your drive will be format
Kingston... | Answered on Oct 29, 2018
I bought a new kingston traveller pen drive with the locking software, I installed it and after deleted the software unaware, now I can't go into my private partition.
Kingston... | Answered on Oct 12, 2017
Not sure if this is of any help.... but I had this exact issue and have just fixed it! (I have a 16gb Kingston USB stick). I had just built a system for someone and was testing the USB ports on the front of their tower and when I got home and plugged in my drive windows decided it was dead/broken! (it either gave a malfunction error or said the USB item was not recognised!) I was not happy!!! ... I then found myself here, not finding a real solution. And then. I plugged and unplugged the drive a few times until it did show up on the 'my computer' screen; windows still gave the message, inaccessible/malfunction etc... I tried to format but windows hung until I unplugged the drive. I had to plug/unplug it again a bunch of times to get my system to see it, and then! I right clicked and used the 'eject' option (thinking maybe it was stuck somehow from when I was testing the USB ports on the new build I had done). Lo and behold it ejected and when I plugged it back in all my data was there! (I'm guessing my guess was maybe in the right ball park, that where I was testing the USB ports I maybe glitched the USB drive boot up/discovery process, and by ejecting it reset it). All in all a simple thing. Any my pen works now!
Kingston... | Answered on Feb 18, 2017
try to put it in another computer..if it is recognized,then the usb version of your laptop differs from the sticks version..if not...means that the memory stick is damaged..
good luck
bye
Kingston... | Answered on Dec 13, 2016
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Kingston... | Answered on Sep 28, 2016
Hello there!
Well somehow data on your usb flash is write protected, maybe before you locked part of your usb pen drive and losted that encryptor software on your usb.
Solution is next, find any software for formatting usb flash memory sticks, force format it and there you go. Thats about it! =)
Sincerely
Aleksandar Adzic
Kingston... | Answered on Dec 01, 2015
USB data-drives use the 'FAT32' file-formatting scheme, to be compatible with both Apple and PC computers.
Open "My Computer", and click with the SECOND (usually the RIGHT) mouse-button on the icon for the drive, and choose 'format'.
Try this:
https://tails.boum.org/doc/first_steps/usb_reset/windows/index.en.html
It worked for me.
Kingston... | Answered on Aug 01, 2015
You don't any driver of the USB drives on XP. The drivers are built-in with the OS. If the USB stick does not work than that might be another problem. Read my previous entries, http://www.fixya.com/support/t4094662-usb_key_problem and http://www.fixya.com/support/t4202542-when_plug_in_pc_show_pendrive might be helpful.
Kingston... | Answered on Apr 17, 2015
In Windows Explorer, click the column heading for name. That should sort them by name.
Kingston... | Answered on Aug 04, 2014
Name: Kingston DT 101 G2 (USB2.0)
Logic Driver: L:\
VID&PID: Vid_0951&Pid_1642
Speed: high speed
VendorID: Kingston
ProductID: DT 101 G2
Product Revision: 1.00 what s the softwar for this flash??
Kingston... | Answered on Jul 07, 2014
try put it in a different pc and see or maybe it's full
Kingston... | Answered on May 08, 2014
1,273 questions posted
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Computers & Internet
Most Popular Question
format 8 gb usb sandisk
  • Computers & Internet
