20 Most Recent Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media Questions & Answers
2answers
How to download an mp3 songs to my 4GB flash
Either you can download a mp3 song from internet to your computer and transfer it to your mobile using a data cable to your mobile memory card.
OR
If you have internet facility in your mobile go to the mp3 site from your mobile and download the mp3 song directly to your mobiles memory card.
Hope this helps, please leave a comment and rate if this solutions was helpful, thanks!
10/18/2021 9:17:26 AM • Transcend 4GB... • Answered on Oct 18, 2021
I have a transcend jetflash
i would probably try formatting the usb to ntfs as the old default fat32 format has issues with larger files, if that still doesn't work the usb is probably faulty and needs replacing. hope that helps, don't forget to mark this answer if it helps
10/17/2019 12:38:49 PM • Transcend 4GB... • Answered on Oct 17, 2019
Can't play my 4GB Transcend
Hi Aking, let's start at the begining, you'r usb stick has been infected and you formatted it. Did it ever work with the player? Assuming it had. Often this sort of stuff happens when file format is incompatible with the device. New operating system of a PC used to reformat might cause it. If you could refer to the manual of the player and check which usb formats it supports then move the data off the usb stick and reformat it according to the specification, you should be able to put the data back on and it should work. If above didn't help time to blame either of the pieces of hardware: usb stick or usb port on the player. capture-3bzj335i3sdxgllsrtr5gtwe-5-0.jpg
9/7/2017 8:25:24 PM • Transcend 4GB... • Answered on Sep 07, 2017
2answers
HI. i am ajay from India.Now i am using fedora
this issue generally comes with unrecognisable partition types in linux
12/13/2016 8:01:48 PM • Transcend 4GB... • Answered on Dec 13, 2016
8answers
I am having one 4gb
Don't be panic. you can try some data recovery software. You can seehttp://www.asoftech.com/adr/index.htmlIt tells the steps how to perform data recovery.If above does not work, you may have to format the pen drive (use quick format), and then use above mentioned software to scan again the pen drive and recover your files.
8/24/2016 3:41:45 AM • Transcend 4GB... • Answered on Aug 24, 2016
2answers
I have TRANSCEND D33193 when i
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
8/10/2016 7:26:16 PM • Transcend 4GB... • Answered on Aug 10, 2016
My pendrive (d33193) gets heated
No solution, it is damaged now due to high voltage current which it could not handle. Flash drives are easily damaged by such problems. All data gone, bye bye.
8/10/2016 7:11:08 PM • Transcend 4GB... • Answered on Aug 10, 2016
3answers
How to recover flashdrive transcened 4gb v30, it
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
11/12/2015 1:28:58 AM • Transcend 4GB... • Answered on Nov 12, 2015
2answers
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
11/6/2015 1:56:00 AM • Transcend 4GB... • Answered on Nov 06, 2015
3answers
I could n't access my files in my pendrive JF V30
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.CardRecovery.com
11/6/2015 1:50:15 AM • Transcend 4GB... • Answered on Nov 06, 2015
2answers
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible1. Damage to partition table2. Damage to firmwareTo fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.JetFlash Online Recovery, you can download here Transcend Customer SupportHow to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.Hopefully this information helps
11/3/2015 1:34:48 AM • Transcend 4GB... • Answered on Nov 03, 2015
3answers
Unable to open my 32GB transcend USB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
10/28/2015 2:56:19 AM • Transcend 4GB... • Answered on Oct 28, 2015
2answers
I have transcend 4GB pen
Try the following link for a utility to help you out.
http://www.freedownloadscenter.com/live/how-to-format-transcend-pen-drive/drive.html
10/23/2015 1:32:34 AM • Transcend 4GB... • Answered on Oct 23, 2015
3answers
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
10/14/2015 1:38:54 AM • Transcend 4GB... • Answered on Oct 14, 2015
2answers
My pen drive is in RAW file system, I ca'nt open or format it.
Try to get a software called parted magic. its linux based and you should easily format the pen drive.
U can also try HP USB Disk Format Tool.
10/13/2015 1:41:21 AM • Transcend 4GB... • Answered on Oct 13, 2015
3answers
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
8/24/2015 8:09:22 AM • Transcend 4GB... • Answered on Aug 24, 2015
3answers
My pen drive is not
u need to formate your pen drive, with low level formatting.
3/22/2015 1:50:26 PM • Transcend 4GB... • Answered on Mar 22, 2015
3answers
7answers
How can i convert 4GB pendrive to 8GB ...?
can i convert the 4gb pendrive to 8gb..?
this is because the mc used in both are same, how to change default firmware installed in mc that flashes and make mc to increase its intensity of storage...if any1 kno..pls tell me da process..
2/18/2015 2:44:07 AM • Transcend 4GB... • Answered on Feb 18, 2015
Electronics - Others Logo
598 questions posted
Top Transcend Electronics - Others Experts
NOEL
NOEL
Larry
August Brown
August Brown
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Transcend Electronics - Others
Most Popular Question
remove write protect from 4 gb transcend
  • Electronics - Others
