20 Most Recent Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive Questions & Answers
How can we repair a USB which is crashed like a
Dear i have send some information of solve your problem. I hope you have satisfied my suspicion if you can solve your problem you can read this information
Thanks.
Pen drive is the best way for people who are looking for larger space to store their important data and want a compact, easy-to-operate storage drive. These pen drives are mainly trendy among system and network administrators. They can load a large amount of information about configuration and software that can be used for the system maintenance, recovery and troubleshooting. But what if there is a problem with your pen drive having important documents have been crashed? Ddipr.com releases new USB repair software to ensure user to get back files and folders stored in USB pen drive.
Pen drive data recovery software securely restores lost digital images, office documents, database files, audio, video files etc from your damaged and logically crashed USB pen drive.
Ddipr provides advanced and professional USB repair application to recover missing or erased files and folders lost due to accidental deletion, virus attack, software malfunction or power failure etc from corrupted or formatted pen drive. Kingston pen drive files undelete utility easily restore data from various USB drive (flash drive, memory stick, jump drive, thumb drive, key drive) and many more USB drives. Thumb drive data restoration program provides reliable and secure method to recover all digital files format including midi, ppt, doc, pdf, mov, xls, jpg, gif, mp3, wav, exe, bmp etc. Software support pen drive in all capacities including 512MB, 1GB, 4GB, 8GB, 16GB, 32GB and even higher capacity drives. USB drive data backup utility support all leading brands like Kingmax, Samsung, Sony, Toshiba, Jet flash, Apacer, Lexar and many more. Software easily installs on all windows operating system such as Vista, 98, 2000, 2003, XP, ME, NT. The software development team of ddipr.com combines a variety of advance features in this particular software. Some of the important features are:
- Pen drive data salvage program recovers data even if Drive Not Formatted message is displayed on your computer.
- Software provides GUI interface which makes it easy to use and operate.
- Application supports all versions of windows like Vista, 98, 2000, 2003, XP, ME, NT.
- Software provides easy data recovery from logically crashed or inaccessible pen drive.
I am a company representative and fully satisfied with this application to restore deleted data from formatted or corrupted USB pe
5/22/2019 4:23:31 AM • Kingston... • Answered on May 22, 2019
Disk in drive G not formatted and won't format
luck that it would not format or all of your school information would be wiped clean That is what formatting means ---clean page , no data , nothing do it again and press no when the question comes up
11/28/2017 4:11:19 AM • Kingston... • Answered on Nov 28, 2017
0answers
2answers
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table Solution: 1. Save the data. To saved data, you can use EASEUS Data Recovery software. 2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7) How to install the HP Drive Key Boot Utility to the operating system Win XP: double click the file cp006049.exe - select Install Win Vista & 7: double click the file cp006049.exe - select extrackHow to use the software HP Drive Key Boot Utility For Win XP, first way: Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive. For Win XP, second way: Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.For Win Vista & 7, first way:Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.For Win Vista & 7, second way: Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.Description initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool. How to restore the capacity of flash drive Kingston9_27_2011_11_26_49_pm.jpgOpen HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish Hope it helps
7/2/2015 7:34:06 PM • Kingston... • Answered on Jul 02, 2015
Pend drive
Scanning by what? What OS?
3/28/2014 1:40:08 AM • Kingston... • Answered on Mar 28, 2014
5answers
Pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
2/14/2014 12:06:26 PM • Kingston... • Answered on Feb 14, 2014
Hi My pendrive is write protwcted, Pendrive is
Some pen drives have a small toggle switch with them which make the drive write protected try locating that switch. If there is no such switch then try formatting the drive preferably from safe mode. you can do this by following these steps:1. Shutdown your computer or laptop 2. Insert USB Memory Stick into your laptop or Computer 3. Turn on laptop and then immediately start pressing (Fcool.png key then Advanced Boot Options screen will come up 4. Select Safe Mode with Command Prompt 5. After loading files if your USB Memory Stick drive letter is (G) for example then write as 6. C:\windows\system32>G: and press enter 7. G:\>format G: and press enter 8. If ask you (Y/N) then press (Y) and press enter 9. Now a full format will start which remove write protection from USB Memory Stick.
9/23/2013 2:57:15 PM • Kingston... • Answered on Sep 23, 2013
Data recovery from pen drive
Dear,
There is a fact the problem may be due to that and it is - Capacity of pen drive . Most of the time pen drive of capacity 1, 2, 4 GB are supported by P-III, not 8 GB,please check it.
Do one thing check it on another PC. if the result is same then you should visit your nearest service station.
Thanks and regards,
Raksh Kumar
3/20/2013 7:31:09 AM • Kingston... • Answered on Mar 20, 2013
3answers
Kingston 32gb pendrive complete format
Dear Chandu!
Try formating in safe mode, as well as make sure that all the programs and utilities are stopped before formating it( you Can use Task Manager for that) ,Use an updated anti virus program for scanning it from viruses.
9/23/2012 2:44:59 PM • Kingston... • Answered on Sep 23, 2012
My kingston DT 101 wont performed because of an l/0 device error
If the drive fails to format, you can try it in other USB ports or a different computer. But if it continues to fail format then it is bad and needs to be replaced.
7/31/2012 12:28:19 PM • Kingston... • Answered on Jul 31, 2012
After used HPformat wont be formating and give me there is no madia in specified device
Please Re Formating And Try It Please Delete The Reclye Bin.
7/31/2012 7:46:51 AM • Kingston... • Answered on Jul 31, 2012
How to delete write protected files from pe
Are the files write protected or just your usb driveright click on the file select properties security make sure you have full controlYou have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. if you need more help with this post a reply hope it helps
5/26/2012 8:30:29 PM • Kingston... • Answered on May 26, 2012
3answers
I cant remove the write protection of my kingston
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
2/5/2012 7:56:44 AM • Kingston... • Answered on Feb 05, 2012
2answers
Transfering data on to a flash drive
You just use them as a regular drive. Plug into a spare USB port Navigate to my computer (or windows explorer) You will see the USB drive as removable drive E or similar. Just drag your files there or alternatively copy and paste
2/5/2012 1:43:19 AM • Kingston... • Answered on Feb 05, 2012
My KINGSTON Datatraveler 16 GB
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
2/5/2012 1:39:53 AM • Kingston... • Answered on Feb 05, 2012
2answers
Help
hi
use antvirus software for virus removal
for formating right click on the pendrive and in properties u have a format option
2/5/2012 1:36:40 AM • Kingston... • Answered on Feb 05, 2012
2answers
"Plsase insert a disk in the drive" message for USB drive
Up to you,, if you put a flash drive into your USB port, and windows see's the drive, because its listed under my computer, but when you go to open the drive it says, please insert disk
This is telling you the flash drive has failed.
The only good thing is, if you have anything on the drive, there are programs that will extract the data from the drive so you don't lose it.
You have three options,
Extract the data that is on the drive.
Try a repair program, which can erase the drive when it tries ti repair it.
Send the flash drive to the company for repair.
2/5/2012 1:33:01 AM • Kingston... • Answered on Feb 05, 2012
My flash when enter in
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this hope this helps you
12/23/2011 10:47:51 PM • Kingston... • Answered on Dec 23, 2011
Computers & Internet Logo
Popular Tags
224 questions posted
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Computers & Internet
Most Popular Question
repair usb crashed like
  • Computers & Internet
