20 Most Recent Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Questions & Answers
Hi johnny_johnm
PLEASE RATE MY ANSWER IF YOU FIND IT HELPFUL !
If your flash drive data is still getting corrupted After going to My Computer, Right click the Removable drive, Go to Properties >Tools. Run Error Checking and Scan for errors and fix them. The files that are corrupt or in bad sectors already will not work but at least the new transferred files should work.
scandrive5ze.jpg If all fails, format your drive. It will delete all the data from your USB drive and make it fresh and hopefully remove all errors. The software for formatting comes on the CD or available on support sites for your branded usb drive on the net. For some reason, when I ran this formatting software, it would say the USB drive is not connected.
How did I format my flash drive? Right click removable drive and select and format the drive. Then scan and fixes all errors. So all the bad sectors are fixed and my drive has become all new and is working well now.
formatdrive3ji.jpg In the File System drop down, you will see FAT and FAT32. So which one to select?
If you right click Removable Drive >Properties
driveprop2hf.jpg The General Properties of the USB drive reveals it is FAT, so I use FAT in the format utility. Then just select "Quick Format" and "Start" and all data will be deleted and hopefully all errors are now gone
Kingston... | Answered on May 17, 2014
You have to be the computers administrator to change any values on any hard drive on your computer. Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP Click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer you should see your usb drive right click then select format another way is to control panel administrative tools computer management disk management right click on your drive select format
If you need more help with this post a reply
Hope this helps.
Kingston... | Answered on Jan 24, 2013
The file system is likely corrupted. This can happen if you remove the usb drive from the computer without clicking "Safely remove hardware' first, (in your taskbar).
There is little chance that you can recover the data.
Just in case, try inserting the drive into different usb ports, preferably also on different computers. If the result is always the same, you will have to format your drive.
Insert the drive into a usb port. Assuming you use windows, click Start, click My Computer, find your USB drive in the list and RIGHT click on it. You will see a Format option. Click on that and use default or FAT. A quick format should do.
Good luck.
Kingston... | Answered on Dec 19, 2012
If you format the flash drive you will lose your data.
Recuva (pronounced"recover") is a freeware Windows utility to restore files that havebeen accidentally deleted from your computer. This includes files emptied fromthe Recycle bin as well as images and other files that have been deleted byuser error from digital camera memory cards or MP3 players. It will even bringback files that have been deleted from your iPod, or by bugs, crashes andviruses!
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuvahttp://download.cnet.com/Recuva/3000-2242_4-10753287.htmlwww.filehippo.com/download_recuva
Kingston... | Answered on Apr 20, 2012
Hi DuuuX,
This is an indication that the file system has become corupted. All you can do is contact Kingston for a warranty replacement.
Kingston Tech Support
Kingston... | Answered on Feb 05, 2012
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your kingston usb drive select format
if you need more help with this post a reply
hope this helps you
Kingston... | Answered on Sep 14, 2011
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Kingston... | Answered on Aug 24, 2011
Of course, unlike most CDs which you can't rewrite, USB sticks work like hard drives. You can write anything on them at any time, until it's full. And of course when you remove files from the USB stick you can clear more space and you can add new files.
I hope I was able to help.
Kingston... | Answered on Jul 27, 2011
your flash is now defective. buy new one.
Kingston... | Answered on Jul 25, 2011
what you need to do is connect your usb drive, then open a command prompt window (Programs->accesories) and in this window type:
diskpart.exe
and press enter
you will be presented with another window similar to the first. In this new window type:
list volume
and press enter
this will show you a list of all drives connected to your machine.
Next type:
select volume *
where * is the volume number of the required drive listed in the list volume section.
and press enter
This will select the drive for the change you are about to make.
type:
detail volume
and press enter
this will list all of the attributes to do with the selected drive, you should see in there that the disk is write protected.
next type:
ATTRIBUTES DISK CLEAR READONLY
and press enter. Once the window has finished what it's doing you can close all of the command prompt windows and your disk should be ready to use again.
Hope this wasn't too long winded and has been of some use to you.
Kingston... | Answered on May 06, 2011
sounds like a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
Kingston... | Answered on Apr 19, 2011
My friend, this USB is damages, it need reparation, if you have windows 7, it launches a fixing program as soon as the usb disc is plugged, try to choose the scan and repair option, it must have been damages by viruses.
Kingston... | Answered on Mar 29, 2011
fomat is not same it is 32 bits not nf.
Kingston... | Answered on Mar 28, 2011
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps don
Kingston... | Answered on Feb 28, 2011
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
81 questions posted
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Computers & Internet
Most Popular Question
kingston datatraveler 1gb while
  • Computers & Internet
