20 Most Recent SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Questions & Answers
You could try this software it sounds pretty good although I have not used it so I am unable to direct you on how but it reads as though it has a password reset tool as well as windows password cleaner and a blank the password utility on any user that has a valid account on windows system and many other tools you might find helpful http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
SanDisk 2GB... | Answered on Jun 10, 2019
Go to Disk Utilities and reformat the pen drive. That might do the trick.
All the best!
SanDisk 2GB... | Answered on Nov 01, 2018
Hi, there. I suppose you must mean to recover data lost from your digital device. In this case, FileRetrieval is one of the best option. It can recover most file formats. If you are running mac os x, go to Data Recovery for Mac.
But just remember - DO NOT write anything back until you get the deleted data back. Best regards.
SanDisk 2GB... | Answered on Aug 27, 2018
Look in Device Manager and see if any USB ports need a driver update. Please click Comment to reply.
SanDisk 2GB... | Answered on Mar 04, 2018
Try connecting the SANDISK to a different computer. It *should* fit.
Try connecting the SANDISK to a different USB port on your computer. It *should* fit.
SanDisk 2GB... | Answered on Jan 14, 2018
Easiest thing to do if you do not know how to log in as administrator is purchase a new usb device and start a fresh. If you get issues, formatting the new drive will not lose any information that is already there.
SanDisk 2GB... | Answered on Oct 28, 2017
Have you ever tried not to enter pswd at all?
SanDisk 2GB... | Answered on Mar 26, 2017
pls phone to:
Asia/Pacific Rim Regional Sales Office, Hong Kong
SanDisk Hong Kong Ltd
Suite 902-903, Bank of East Asia Harbour View Centre
56 Gloucester Road
Wanchai, Hong Kong
Phone: 852-2712-0501
Fax: 852-2712-9385
SanDisk 2GB... | Answered on Mar 02, 2017
Since you are using Macbook, you can go to this program USB Flash Drive Recovery for Mac for help. If you are running a computer with Windows, go to Data Recovery for Windows. It should help you out.
Note: before recovery, DO NOT save more files to the USB drive.
SanDisk 2GB... | Answered on Jan 09, 2017
I have not posted a help request, so I do not know how the picture is tied to this question ? If your cell phone has a standard SD memory card, there are a couple of ways to "transfer" pictures and music.
1. Your SD chip MAY have come with a larger carrier to fit into some of the computer SD slots that have been provided over the past few years for cameras, etc ? Once plugged in, your computer should recognize it like a small USB flash drive, then it's a matter of cut-n-paste.
2. Alternative is to go to Fry's Electronics and pick up a USB-to-Your Cell Phone adapter cable.. mine, for my Samsung Gravity was $15.00. Then, at least on my phone, I have the option to switch the USB connector from Modem to Storage drive, pick the latter. Your cell phone manufacturer, like my Samsung, may have a utility program that allows you to "manage" your phone.. contacts, pictures, ringtones, music, etc.. cut-n-paste again.. mine allows me to sync the phone to my Outlook for constant updating, etc..
3. Go to Fry's or ? and pick-up an inexpensive "USB Bluetooth Adapter". Plug it into a USB port on your PC, install the software, have it detect your phone, authorize it, now you're wireless vs corded.. follow the remaining steps in #2 above.
As an added note.. if you have a laptop, and your cell service has an Internet package for your phone, for around $20 month, I have a Highspeed ( 460 kbps ) wireless ( via bluetooth ) or the cord, modem.. AND you can still receive calls ( at least on mine ). AND it doesn't require a Hot Spot, only cell reception.
Respectfully,
Toby White-Beebe
P.O. Box 474
Penryn, CA. 95663
(916) 300-9410 Cell
(916) 473-7409 Home Fax
2008 VA Certified NACI Low Risk Security Clearance
2008 VA OCIS/ROB Affirmation of Compliance
2008 VA Certified OIT Contractor
2008 Dell Certified Lead Systems Expert - DCSE
1999 A+ Certified Service Technician
SanDisk 2GB... | Answered on Dec 16, 2016
HI Friend..!!!!!
try this
1. Insert your pen drive in computer and don't take it out.
2. Place WinXP Cd in CD-Rom
3. Restart your Computer
4. When your computer prompts boot from Cd click any button
5. Wait for upto 5-10 minutes.
6. Now when format screen comes select your pen drive over there.
7. Now install winXP over to it.
8. Now it asks for format.
9. After formatting it copies the files, at that particular moment restart your computer.
10. Remove the Cd from CD-Rom and the pen drive from computer.
11. Now when your computer is restarted insert your pendrive and delete if there is any unneccessary file exists.
12. Now you'll feel that your Pendrive is in OK condition.
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards'
sandy
SanDisk 2GB... | Answered on Sep 22, 2016
http://www.sandisk.com/media/175954/80-36-03183.pdf
SanDisk 2GB... | Answered on Dec 07, 2015
1). Do not format this hard drive before you've recovered all your stored data back. In your case, the formatting process may erase everything on your drive and make your data gone permanently.
2). Never save anything new on this drive in case that any new file would rewrite your original data.
3). Plunge this drive to your computer and download a RAW drive data recovery freeware to get back all your lost data back:
http://www.freeware-fix.blogspot.com/2013/02/raw-hard-drive-recovery.html
This hard drive has helped many people around me restore their inaccessible data back from a RAW drive or memory card. It can also work perfectly on your drive.
Read more detailed information of this freeware here:
http://blog4mark.blogspot.com/2012/10/help-external-drive-became-raw.html
4). Save and back up all your restored data on another drive in case of data recovery failure.
5). Format this drive to see whether it is fixable.
SanDisk 2GB... | Answered on Sep 25, 2015
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
1,648 questions posted
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • SanDisk Computers & Internet
Most Popular Question
recover data
  • Computers & Internet
