20 Most Recent
Dell Dimension 8300 PC Desktop Questions & Answers
How do i connect two pc together
If they are alrady on te same router / WiFi, make a drive or folder 'shared' and then on the other use 'Map network drive'
If not, then just use any old Ethernet cable to link them (both PC's should be happy enough to set a default IP addresses and 'see' each other) - modern PC's don't need special 'switch over' cables (a 5m Ethernet cable from the £1 shop will work fine)
On the PC you want to 'expose' data, you 'Share' the folder (right click for the folder 'properties', look for 'security/sharing' etc).
On the other you 'map network drive' (if asked for a user name/log-in, use the account on the OTHER PC ..)
How to remove hard drive from dell tower
Open clam-shell type case by pushing buttons on rear top and rear bottom of case and pulling case open like a book. Once case is opened, you\'ll see the hard drive in the right half (as viewed from the back of the PC) Pull the power and data cable from back of the hard drive. Squeeze ends of green plastic slides and pull hard drive from enclosure.
Microphone dosen't work
Just go and buy a microphone on its own, they are cheap maybe 10, it will plug in and work perfectly, you have over complicated yourself
Keyboard failure
have you tried a different keyboard to rule out the keyboard is not faulty which is it a usb or p2p connection are you conecting through a usb hub?
How to restore and then update dell 8300
Usually, after you re-install ... and set UPDATE mode (for Windows & IE) to automatic ... the system will look for and download updates (to Windows, browsers, etc.) automatically. So, shut down and restart ... and let it do it's (automatic) download & install . It may take quite a while, to bring you up to the latest Windows XP version.
Multimedia audio controller driver missing
If you have the disc which came with the motherboard, use it to install the audio controller. However, you can just go to device manager by either:
For Windows Vista and 7
- Click start -> type in "devmgmt.msc" on the startsearch box -> press Enter key
Fow Windows XP
- Click start -> Run -> Type "devmgmt.msc" on the box -> press Enter key
In device manager, right click on the "Unknown devices" and select "Update driver" button. Search the web to find and automatically install the audio driver. (Make sure that you have an internet connection.)
Hope this helps.
