The paper doesn't seem to push through to print. It seems the roller bar is slipping
SOURCE: printer says clear paper jam. There is no paper jam.
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
SOURCE: paper feeds into printer uneven
check for anything obstructing the path of the paper..usually something very tiny! and clean the rollers with toothbrush & water.
SOURCE: PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
tuval.
[email protected]
hope fore replay.... :)
SOURCE: Hi,
get yourself a can of electronic contact cleaner in a arisal can. spray this on a rag and clean the paper feed wheels and the seperator pad (cork piece about 3/16 x 1inch) located right under the paper pick wheel.these wheels get glue build up on them and become slippery the contact cleaner will remove the glue with out leaving a residue behind
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Check this link for tips;
http://www.ehow.com/how_113761_clear-printer-paper.html
