20 Most Recent Lexmark X1240 All-In-One InkJet Printer Questions & Answers
4answers
Lexmark all in one center download
I had this same problem and it doesn't look like anyone else has solved it yet. I spoke with tecnical support and got it resolved.
I have windows vista so your instructions might be slightly different.
start> computer> double click the C folder> drivers> printer> 1200(or whatever series printer you have)> applications> then the  set up folder with the CD icon.
It will install the scanner software. Also, the website has been updated on lexmark so that includes the all in one software now. So, if you have the older version from 2008, then delete the old software out of your printer folder and go to lexmark and install the new one.
Any other questions, email me. [email protected]
7/31/2021 7:20:44 AM • Lexmark X1240... • Answered on Jul 31, 2021
My lexmark X1240 will not print color
Hello Jasonsj10, You can get the support you need from Lexmark directly here: Make Your Selection I hope this helps!
2/5/2018 1:47:32 AM • Lexmark X1240... • Answered on Feb 05, 2018
Hideous Color
Still working on it. The weekends are my best bet as I have little time to concentrate after work.
Thank you and I will let you know.
9/9/2017 5:39:05 PM • Lexmark X1240... • Answered on Sep 09, 2017
Lexmark printer cord
You can call Lexmark Tech Support and request one, they will send it out to you.
7/20/2017 7:17:11 AM • Lexmark X1240... • Answered on Jul 20, 2017
Lexmark X1240 starts to print then stops and job gets stuck in print queue.
If you are printing wireless thru a D-Link adapter, you are going thru too many connections. Let me explain: I have worked on electronics most of my life and the old saying goes, "the more breaks you have in a connection, the more chances you have that something, somewhere in between the breaks, will cause you to have more problems". Go thru your Uverse directly with a RJ45 or CAT5 cable, if possible. If not, then hard wire it using a USB switch. This allows multiple devices to use the same printer. Hope this helps.
4/25/2017 5:25:20 PM • Lexmark X1240... • Answered on Apr 25, 2017
2answers
My Lexmark x1240 won't print anything. I click on
uninstall the printer and reinstall it if it says it is printing to your printer. under printers your printer should be set as default. test by selecting print from the menu. it should come up to a screen showing you which printer you are printing to.
3/21/2017 1:02:29 AM • Lexmark X1240... • Answered on Mar 21, 2017
3answers
Can I connect my Lexmark x1240 directly to wall outlet without the adapter by stripping the cords wires and attaching them to two inner prongs on back of printer where adapter goes
no will damage the printer the unit has an adapter for a reason and a new one is inexpensive
11/3/2016 11:22:54 AM • Lexmark X1240... • Answered on Nov 03, 2016
0answers
Brother DCP-130C Printer
Hey rip
Have you made the brother printer the default?
Have you installed the OCR software?
Some OCR software packages prefer you to scan into a document.
I use a HP unit that will not allow me to scan a document unless I scan it into a compatible software format, written or typed pages into WORD, photos in photoshop etc.
Try uninstalling the printer and then reinstalling it again
Turn off, any anti virus and firewall software you may have running and if you can update the software from within itself, update it
Dont forget to turn your anti virus and firewall software on after you have finished
go to the Brother website and download the latest drivers for use with your chosen operating system
Have fun !!
Swoop611
12/5/2015 7:52:56 AM • Lexmark X1240... • Answered on Dec 05, 2015
Lexmark x1240 manual
11/28/2014 6:32:04 PM • Lexmark X1240... • Answered on Nov 28, 2014
Installed new cartridge still won't print
It could be that your printhead needs cleaning. Open the Lexmark Solution Center application on your computer. Go to the Maintenance tab and select Clean to fix horizontal streaks. Your printer will then print a page, forcing ink through the cartridge nozzles and clean them. Then try to print a document again to verify that the print quality has improved.
9/4/2014 2:40:00 AM • Lexmark X1240... • Answered on Sep 04, 2014
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
6/21/2014 9:12:54 PM • Lexmark X1240... • Answered on Jun 21, 2014
Download dsm415pf cd
gamal, do you mean installing software using your cd. IF that, then using cd drive and following on screen direction should do it. I hope you cd drive is ok.
5/2/2014 5:15:18 AM • Lexmark X1240... • Answered on May 02, 2014
Scans half way and then blurs the rest of the page
check the scanner belt and moter it may stuk
11/21/2013 2:53:47 AM • Lexmark X1240... • Answered on Nov 21, 2013
Lexmark X1240 All-In-One InkJet Printer Logo
617 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
lexmark x1240 print anything click
  • Office Equipment & Supplies
