20 Most Recent
Canon PIXMA iP8500 InkJet Photo Printer Questions & Answers
Error Number : 300 The printer does not respond. Make sure that the printer is plugged in, powered-on, and properly connected to your computer.
I had this problem with a Canon IP5200R connecting to a Mac Book Pro running Leopard. I had setup the printer as per instructions using the setup utility, could print a test page using the utils but could not print from an app.
My solution was to delete the printer (System Prefs > Print & Fax) listed in the system preferences and then re-add by clicking the '+' in the pref panel, then selecting 'More Printers' from the popup window. If you have the printer connected to the network correctly it should show up and you can simply re-add it. My printing now works correctly.
Canon Pixma ip8500
Is there any chance the feed / supply rollers etc have got any ink on them and need a clean.?
PIXMA iP8500
Error 5100 on Canon Pixma iP8500. flashes orange 2 times. Sounds like the paper isn't being picked up. But I don't know how to fix it.
Ptinter start up
Hi, Try reloading the software that came with the printer. Hope this helps. all the best.
