My 6 month old washing machine has just made some scary bangs, before turning itself off and then on again. It then did the same thing again. It sounded like it was shorting out badly inside so turned it off immediately, but there was a strong smell of burning. Worries me that if I hadn't been in the room then it could have beena fire. As its so new I know I can get it sorted under warrenty but feel that there may have been a major risk to my family. I've attached some link to some pics below. http://postimg.org/image/lpvuedh91/ http://postimg.org/image/j11n609gl/ http://postimg.org/image/5o0cexzl7/ Thanks in advance
YOU COULD HAVE A LOOSE WIRE IN THE RECEPTACLE IN THE WALL THAT THE WASHER IS PLUGGED INTO YOU MAY BE SMART TO HAVE AN ELECTRICIAN CHECK YOUR WALL PLUG OR AN EXPERIENCED HANDYMAN? THANKS JOHN
SOURCE: WMA30 Front loader
CHECK YOUR DRUM BELT FOR CRACKS AND SIGNS OF WEAR BY TURNING TRHE BELT INSIDE OUT AND SLOWLY TURNING IT TO FIND CRACKS. THE BELT TENSION ADJUSTMENT PULLY MAYBE CRACKED OR WORN AS WELL.
SOURCE: washing machine
Check the brushes in the motor. They've probably worn down and need replacing.
SOURCE: Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
SOURCE: My 3-year old (plus 2 months) Speed Queen washing
Here are some links that I hope will help you.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=106331&diagram_id=317200#d317200
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=244815&ST=PBM
SOURCE: I got a new Matag
Thanks for choosing FixYa and welcome. You are going to need to clean the washer. You need to get inside the washer and clean the tub, hoses, and water pump. Articles of clothing and other items get stuck in these places. Once you clean it, run a load of bleach water through the system. This should take care of your smell.
