20 Most Recent Hotpoint WMTL80 Top Load Washer Questions & Answers
first thing to check would be the agitator dawgs if you can free spin the agitator when the unit is off then this is what you would have to replace think they cose about 5-7 dollars on the other hand if you set the unit to spin and the unit spins and then you use your hand against the side wall to slow the tub down if the tub slows then you would have a faulty clutch both of these are assuming that the motor and transmission are working properly and in order to check both of these you would need to remove the cabinet if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Hotpoint WMTL80... | Answered on Feb 19, 2011
Chances are the wiring underneath to the transmission solinoid has broken. You'll have to drain the washer by laying the drain hose on the floor in a pan. Then turtle (flip on it's side) on a pad/carpet carefully and remove the back panel and trace the wires with a flashlight, If you find the break you can try a heavy duty **** splice but my experiences tell me adding wires to lengthing that cable is a better choice.
Hotpoint WMTL80... | Answered on Jul 28, 2009
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Hotpoint WMTL80... | Answered on Jan 15, 2009
From the information you have supplied, I suspect that the door interlock switch may be faulty. But without more information, it is difficult to be certain.
I hope this helps?
Hotpoint Washing... | Answered on Sep 10, 2019
Is it in demonstration mode ..... look at your instruction booklet to stop demonstration mode. They are similar but vary with model types and numbers.
Hotpoint Washing... | Answered on Sep 08, 2019
Unplug it from electric socket to see if that unlocks it.
Hotpoint Washing... | Answered on Aug 22, 2019
It seems that the door cannot be locked.
Check that the door closes correctly and you hear the click when it closes. If this is ok and you cannot start any cycle but continue hear clicking, then you have a problem with the door lock latch and needs to be replaced. Here is a video of how you can do it after you buy the spare part, according to the model and serial number of your appliance. The video is for a different brand of washer but don't worry the process is exactly the same!
If you think you can't fix it your own, you should call an engineer.. Washer Door Lock Assembly part 131763202 How To Replace
Hotpoint Washing... | Answered on Aug 01, 2019
Most likely the main oven element has blown. A new element will cost about £20-£40, and if you're reasonably competent you can swap it in around 15 minutes. Turn the power off, undo the screws holding the element and pull it out. Carefully disconnect the push on terminals and take the element out. You probably won't even need to test the element with a multimeter, as you'll easily see if it's blown as the insulation will have blown off. nb. You may have to remove a cover before you can get at the element but should only be 4 screws max. Refitting is reversal of removal, just make sure the wires don't fall back behind the oven casing before you reconnect them!
Hotpoint Washing... | Answered on Jun 26, 2019
Ok that might be for your filter it might be full. You can check that from inside the shell or should be one the tub.
Hotpoint Washing... | Answered on Jun 13, 2019
Hi
F06 is for a door lock fault.
In order to get the door open you will need to drain any water still in the tub by lowering the drain hose into a bowl at floor level. This should then allow the door lock to open.
if the door still does not open, then you will need to access the door lock from inside the machine via removal of the top panel of the machine. Check the cable connections to the lock if ok then next check the motor brushes for wear.
Hotpoint Washing... | Answered on May 28, 2019
Hotpoint WMTL80 Top Load Washer Logo
13 questions posted
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint wmtl80 washing machine not
  • Washing Machines
