20 Most Recent Kenmore 3.8 cu. ft. HE3t Front Load Washer Questions & Answers
2answers
Kenmore HE3t Frontloader Fills Up With Water After Cycle
Does this change if you select a cold wash or a hot wash? What's the water temperature feel like when it fills? I'd suspect the water control solenoid for either the hot or cold water isn't shutting off completely. This could possibly be due to a piece of debris or mineral deposit in its seat, and could be cleaned with CLR or citric acid if you remove it. They're not very expensive and not a very hard item to change on most machines.
11/7/2017 3:17:02 PM • Kenmore 3.8 cu.... • Answered on Nov 07, 2017
Kenmore Elite He3t washer doesnt
check the cleanout on the pump,most likely there's junk clogging the pump.
9/30/2017 3:56:59 AM • Kenmore 3.8 cu.... • Answered on Sep 30, 2017
0answers
How to replace the drum baffles on a Kenmore HE3 front load washer?
Hello Dennis Appliancepartspros does indeed show an entire kit for EXACTLY YOUR problem... $34 Good time to compare SEARs prices... for those very same parts!! Happy hunting!! Sears Water Filters Lawn Garden Appliance Parts Appliance parts http://www.appliancepartspros.com/search.aspx?model=kenmore%20he3t
5/18/2016 7:21:09 AM • Kenmore 3.8 cu.... • Answered on May 18, 2016
2answers
Water continues to drip in after complete cycle
Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. A bad solenoid will permit water to leak through to the tub. Hope this helped and best wishes.
8/4/2015 2:04:25 PM • Kenmore 3.8 cu.... • Answered on Aug 04, 2015
Kenmore HE3t won't start, makes short buzzing
door lock is the first place I would start. If it keeps doing it after the lock checks good, then it would have to be the control board.
3/6/2015 1:07:38 AM • Kenmore 3.8 cu.... • Answered on Mar 06, 2015
My front load washer will not spin
blockage or pump problem
3/2/2015 12:26:02 AM • Kenmore 3.8 cu.... • Answered on Mar 02, 2015
My HE3t Kenmore washer will not start. All the lights come on and you can select the cycle but the start button will not start the machine. We did unplug it to reset the machine but that did not wor
This may be a stupid question...but is the water turned on? Stranger things have happened!If the drum inside doesn\'t turn, it may be an electronic issue. Hopefully the washer is under warranty. Best of luck!
10/9/2014 11:20:50 PM • Kenmore 3.8 cu.... • Answered on Oct 09, 2014
Zerowatt
go to this webpage http://www.shopyourway.com/manuals/search?q=washer%2C+kenmore%2C+4586 search for "4586" which Kenmore tells me is model number. You will find a number of manuals; all seem to point to this one http://www.shopyourway.com/manuals/7537 (for example) Is it this one (I would add a pf file but I don't seem to able to....) 14.April.2014
4/14/2014 6:33:28 PM • Kenmore 3.8 cu.... • Answered on Apr 14, 2014
Control locked light is on
find the button that it says "press and hold 3 secs to lock and unlock control"
2/28/2014 6:23:54 AM • Kenmore 3.8 cu.... • Answered on Feb 28, 2014
F DL Error Code
If you were already experiencing the F11 error code and now experiencing the Fdl error, this more than likely is a failure of the Main Control Board. F11 is a serial communications error associated with the Main Control Board, while the Fdl error is either a failed Main Control Board and/or door latch. You can replace the door latch first to see if the error goes away, but I would almost bet you have a control board problem since you were already experiencing an intermittent error code associated to it. Let me know if you have any further questions.
1/23/2014 12:05:00 AM • Kenmore 3.8 cu.... • Answered on Jan 23, 2014
Got an F6 error code in my Kenmore HE3t front load
This is not a Computer Processor issue. Wrong section.
10/24/2013 6:34:50 AM • Kenmore 3.8 cu.... • Answered on Oct 24, 2013
311 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
replace drum baffles kenmore he3 front
  • Washing Machines
