How to replace drum baffle
SOURCE: How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
SOURCE: NO power or dead control board with maytag washer mah9700aww
Are you getting power at the wall plug? Test it with a lamp or nitelite. GFI are made to protect people and need to be tested annualy by the button on the plug. You also have to reset it by the plug or circuit breaker. If the washer is on the same circuit as something else that uses high current it may too much current for the circuit. It use to be that we could not wash clothes and use the microwave so I moved the microwave.
