20 Most Recent Maytag Neptune MDE5500AY Electric Dryer Questions & Answers
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Maytag Neptune... | Answered on Oct 02, 2019
Sure I will help you when that happens that means that your heater core is no longer operating and when the heater core doesn't work when your dryer doesn't heat up anymore so that's your problem I hope I have helped you please leave a response or Stars if I have helped
Maytag Neptune... | Answered on Feb 07, 2018
near fan blower ,had a fuse white by pass than try if work change it than clean the vent
Maytag Neptune... | Answered on Nov 14, 2017
the female is the switch! you can pop the top off and check with electric tester on ohms, make sure you unplug the drye
check the breaker make sure you have 220 volts a in the outlet !
Maytag Neptune... | Answered on Aug 16, 2017
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Maytag Neptune... | Answered on Jul 26, 2017
Looks like your drive motor is locked up. It has an internal overload switch which cuts power off when motor gets too hot...Replacement of the motor on a used dryer is probably not the best choice as it can be quite pricey..
Maytag Neptune... | Answered on Jul 10, 2017
check the exhaust tube for obstructions
Maytag Neptune... | Answered on Oct 26, 2016
Disconnect power or turn breaker off for about 5 minutes. This may reset the unit. Otherwise you have an eror showing and need to retrieve the error code. Google your make and model followed by error codes a d you should get a link to retrieve the codes.
Maytag Neptune... | Answered on Aug 09, 2016
This may be from a key that is stuck on the panel. Press each key individually to see if all of them move up and down.
Maytag Neptune... | Answered on Jun 30, 2016
Pf shows a power failure hols the stop clear button and it should work again.As for your other problems I will more details such as a model number Gas or Electric dryer and example of the problem in detail
Maytag Neptune... | Answered on Apr 14, 2016
Type Maytag Neptune push pad into YouTube and see if the video comes up, thanks!
We have the same machine. The drum also broke so we had it professionally installed. It wasn't done well enough and after the 90 day repair warranty, other problems developed. We still don't have a dryer and the next repair is $500 as other parts were damaged and we didn't catch it within the 90 days.
Bottom line: do have it professionally installed but be sure to ask about their work guarantee. As soon as you have any problem at all, call them back.
Maytag Neptune... | Answered on Feb 07, 2016
on board fuse or control card cooked
Maytag Neptune... | Answered on Jan 25, 2016
sounds like its hung in a loop unplug wait a few min. plug back in
Maytag Neptune... | Answered on Dec 24, 2015
Maytag Neptune MDE5500AY Electric Dryer Logo
2,008 questions posted
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
dryer chirping along following start
  • Dryers
