To reset your Jura S8 coffee machine and remove the stuck drip tray, you can try the following steps:
Unplug the coffee machine and wait a few minutes for the internal components to cool down.
Gently try to wiggle the drip tray to see if you can loosen it from its stuck position. Be careful not to force it, as this could damage the coffee machine.
If the drip tray is still stuck, you can try resetting the coffee machine. To reset the machine, you will need to locate the reset button or switch. This may be located behind the water tank, under the machine, or in the control panel. Consult the owner's manual for the exact location of the reset button.
Once you have located the reset button, press and hold it for a few seconds until the machine resets. This may cause the drip tray to release and be able to be removed.
Hello Barbara, I have one of these dishwashers and this is what happens. There is a drip tray in the bottom of the machine that catches any leaked water. There is a float switch in the drip tray that detects water in the tray. If there is water in the tray, the float switch turns on the drain pump. This will immediately pump all of the water out of the machine and keep the pump running until you remove the water from the drip tray. The pump only pumps out the machine but does not pump from the drip tray. Also the pump will keep running even if the door is open or if the machine cycle is stopped. The only way to stop the pump is to turn off the electricity supply. But also turn off the water supply at the same time, because if the valve that feeds water into the machine is faulty, it will fill the machine till it overflows and if the power is off the float valve cannot turn on the drain pump. On this machine, the solenoid valve that let\'s water into the washer is at the end of the inlet pipe when is connects to the water supply. It is powered by line voltage (230 volts in our case). If this is faulty, it can be replaced with a commercial solenoid valve. The is a two core cable running inside the outer plastic pipe on the inlet pipe. This carries the power to the solenoid valve. To empty the water from the drip tray, remove the panel from the front of the washer. It is below the front door and has two screws on each end. When you remove this you will see a hole on the left that is big enough to put your finger through and feel if there is water in the tray. If there is, push through a small plastic pipe and suck out the water. It does not take much water to switch on the float valve, maybe the door was not closed properly and some water leaked into the bottom of the unit. I gained the above knowledge by bitter experience.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Hi Lift up on the front of the drip tray and pull out the front. There are 2 locking pins on the bottom of the drip tray that lock into the machine, that is why you lift up on the front of the drip tray before you pull out.
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Hi Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position. When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic number for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn’t know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds
Hi Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position. The white thing on the side is for the cappuccinatore. It slides on with a twist. The hose goes into your milk. You twist the little knob on the top when it is steaming until the milk goes up the tube and produces the foam. Once you get the foam going you won't have to move the knob again. Just keep everything clean.
The tray appears to have been inserted just slightly askew, causing the notch in the back of the tray to get hooked under that black bit. I was finally able to remove it by tilting the front upward and pulling out. I have reinserted the tray several times since and it pulled out as simply and smoothly as it usually does.
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
