20 Most Recent Lavazza 2210 Questions & Answers
Error code 11 lavazza blue
lavazza machine lb2600 error code 8
11/1/2020 12:00:09 AM • Lavazza 2210 • Answered on Nov 01, 2020
0answers
0answers
Display message
Be the first to answer 9/14/2017 12:57:03 PM • Lavazza 2210 • Posted on Sep 14, 2017Be the first to answer
Pls tell me were is lava mobile service center in
have a new lava A9. But it hangs when the warranty registration promts to register warranty service, which propts regularly within few hours. So please suggest how to register warranty service or to stop propting.
purchase A New Hand Set 05/01/2011
6/23/2017 6:31:07 AM • Lavazza 2210 • Answered on Jun 23, 2017
3answers
Need service on lavazza blue LB 2210
For more company or product information please call us at 800-524-2343 or email us at info@betson.com
7/11/2016 5:35:20 PM • Lavazza 2210 • Answered on Jul 11, 2016
Lavazza LB 2210 error 82/84
12/3/2014 9:02:24 PM • Lavazza 2210 • Answered on Dec 03, 2014
3answers
Whats the lava a10 security
Dear Sir, This is to inform you that the default password of A10 is "4321"
7/16/2013 8:39:06 AM • Lavazza 2210 • Answered on Jul 16, 2013
Our Lavazza Blue is been
Hello there,
You will have to reset the espresso, then you prime it, then you descale it. That way, it will begin to function as good as new.
There is a reset button at the back of the espresso machine. Try o push it, and it will reset the espresso machine. Then you prime it.
To prime and descale it,
1. Fill the water reservoir up with fresh, cold water. Important: make sure all hoses are submerged and free of kinks or other obstructions and that the inlet hose reaches to the bottom of the reservoir if so designed . 2. Make sure all switches are in the OFF position. Plug machine in. 3. Turn steam knob open. Place container under steam wand. 4. Turn machine on. IMMEDIATELY turn coffee/brew switch on, or the Hot water Switch if so equipped. 5. The pump will sound noisy initially but should quieten down within 10 sec. or so. The water level should start to drop in the reservoir. 6. Close the steam valve once water starts to flow out. Turn the coffee/brew switch (or hot water switch) off once water flows out of brew head. The espresso machine is now primed. Continue to run about a cup of water through the boiler and the group to thoroughly flush the system prior to using the first time 7. VERY IMPORTANT! Shut machine off after 1 minute if water does not appear. Wait 5 minutes for machine element to cool down. Repeat. Check for leaks (water under machine). If the espresso machine won't prime, contact us for further instructions.
In hard water areas, minerals found in the water (such as calcium and magnesium) will accumulate, and over time affect operation of the espresso machine. Approximately every 3 months (depending on your use and the water hardness - check our chart), clean the machine with our Ascor Decal powder (or other natural citric acid based decalcifying agent).
1. Add one packet of Ascor Decal descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results). 2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution. 3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes. 4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes. Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through. 5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty! 6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Hope this information was helpful to you. All the best Elect_Comp
9/10/2011 4:03:51 PM • Lavazza 2210 • Answered on Sep 10, 2011
What is the handset code
Dear Sir, This is to inform you that the handset code for ARC02 is "4321"
8/11/2011 5:26:23 PM • Lavazza 2210 • Answered on Aug 11, 2011
My Lavazza Blue coffee machine
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
8/4/2011 2:25:36 AM • Lavazza 2210 • Answered on Aug 04, 2011
2answers
Just need instructions to descale
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
7/3/2011 10:15:14 AM • Lavazza 2210 • Answered on Jul 03, 2011
The screen says "empty dregdrawer".
  1. Remove the drip tray (it just lifts off)
  2. Pull on the bottom section, this is a drawer which contains the spent capsules.
  3. Empty the drawer.
  4. Replace the drawer and the drip tray.
This video shows how it's done around 6:55: http://www.youtube.com/watch?v=QnJwgnbfmoQ
3/4/2011 5:06:59 AM • Lavazza 2210 • Answered on Mar 04, 2011
0answers
I am considering buying
There is a floating plastic block in the water chamber that sits next to a sensor in the machine, that tells the machine whether the water reservoir is full or not. if its stuck, that could be the simplest fix ever. It could also be the sensor at fault, but it should be easy to test the float first
12/27/2010 8:59:57 PM • Lavazza 2210 • Answered on Dec 27, 2010
2answers
I'm missing My Lavazza water
It wasn't easy to find on their site but here is their customer service contact info:
LUIGI LAVAZZA S.p.A. (Lavazza Customer Service)
VAT number IT00470550013
C.so Novara, 59 - 10154 Turin Italy
Tel. +39 011 2408400
Fax + 39 011 2398333
e-mail: [email protected]
Your best bet is to email them with your model number and original question. I'm sure they'll be able to help you out :)
10/16/2010 3:46:56 AM • Lavazza 2210 • Answered on Oct 16, 2010
Machine is plugged in...but when the switch is
Could be a defective power switch or open line cord/plug. You will need a voltmeter to determine which is at fault.
3/6/2010 8:48:23 PM • Lavazza 2210 • Answered on Mar 06, 2010
Machine is spewing grounds into the cup
This is usually an overfill of grounds or the water distribution nozzle is not distributing the water correctly. First, put no coffee in the unit. Just fill a cup w/hot water. If it still is putting out grounds, the upper basket has coffee grounds stuck in the nozzle. If you get no grounds, try reducing the amount of coffee used.
11/9/2009 7:36:42 PM • Lavazza 2210 • Answered on Nov 09, 2009
Lavazza 2210 Logo
30 questions posted
Top Lavazza Coffee Makers & Espresso Machines Experts
john h
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Lavazza Coffee Makers & Espresso...
  • Lavazza Coffee Makers & Espresso...
Most Popular Question
need service lavazza blue lb 2210
  • Coffee Makers & Espresso Machines
