20 Most Recent Jura Capresso Impressa F9 Espresso Machine Questions & Answers
Probably poor design
Jura Capresso... | Answered on Dec 19, 2017
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Jura Capresso... | Answered on Dec 09, 2017
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
Jura Capresso... | Answered on Oct 26, 2017
pls DIY the repair. Instructions are easy to follow: https://youtu.be/Sz3fyg-36JQ
Jura Capresso... | Answered on Sep 02, 2017
At the time of set up, Jura instructions ask activating the use of Filter cartridges. This eliminates reminders for descaling.
Solution:
Throw away the filter cartridges that are expensive, ineffective & block descaling reminders.
Descale the machine every three months using manual descaling method. See link for instructions. Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Jura Capresso... | Answered on Oct 23, 2016
Insert the tray-all of it except the grounds container.  The message disappears and you can wait until the machine continues it's cycle and then asks to empty the tray.  Empty the tray and place the grounds container back inside.  Whew, I've done this a few times over the years when I am rushing but it fixes it every time.
Jura Capresso... | Answered on Feb 29, 2016
Fish that obstacle out.
Jura Capresso... | Answered on Dec 28, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jura Capresso... | Answered on Nov 06, 2015
sensor is broken or damaged. look for it, or ask a professional repair office.
Jura Capresso... | Answered on May 04, 2015
Hi, I made a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Jura Capresso... | Answered on Mar 23, 2015
Hi, a video how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
Hi, I made some videos how to fix your Jura step by step, good luck... http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
This is the 2nd time in a month since I've had this machine that I had to call support for the same problem. An easy fix! I was instructed to remove the whole 'drawer assembly' and remove the grounds bucket. Insert the assembly without the bucket. Wait a minute, take it out again and replace the bucket. Then you're ready to go. Hope this helps.
Jura Capresso... | Answered on Jan 30, 2015
Jura Capresso Impressa F9 Espresso Machine Logo
167 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Impressa Jura Capresso
  • Impressa Jura Capresso
Most Popular Question
machine requested clean cycle in quite
  • Coffee Makers & Espresso Machines
