20 Most Recent
Jura Capresso Impressa X7 Espresso Machine Questions & Answers
Jura impressa x7 has a malfuction 8 error. what is
In my case the brew group is jammed in the down position - so I could not remove the grounds bucket. I think error 8 may be when the motor is stuck (over taxed) or the brew group is out of position. I opened up the right hand side after removing the back with the jura oval key tool https://www.jura-parts.com/ then removed the metal panel with a tiny torx head screwdriver I could manipulate the cog on the screw thread with my hands - it was very tight. Lubricated this and it seems to be working now.
Error report fill water tank
small black rectangular float is stuck in the water tanks . take off tank and empty. then shake you will see it on the side wall (machine side) if it does not rise when water is filled the machine still thinks its empty
remove tank clean with hot water, rinse and shake you should hear a rattle in the bottom of the tank. if you dont the the small black float built into the tank side wall is stuck. once free it will work fine.
