Start button does not turn the computer on. Charging battery or plugging in charger does not work.
SOURCE: My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
SOURCE: Acer Aspire 5002 Laptop will not stay on
This can be an overheat issue. Either the CPU or the Chipset is overheating. Make sure all your fans are working.
Laptops still turn on with the ac adapter plug in and without a battery plugged in. Nope a bad CMOS battery would give you a warning message on the laptop screen, stating the CMOS battery is low or needs to be replaced.
Also does your battery hold a charge? If so with the battery plug in only (without the ac adapter plugged in) does the laptop do the same thing?
SOURCE: I am having a problem with my acer travelmate
Test the power pack with a multimeter. If it is not giving out the correct voltage, then your power pack is bad. If it is good, replace the battery.
SOURCE: battery not charging
If the Acer is brand new then it is under warranty. Take it back to where you bought the Acer and get it fixed under warranty. if you attempt to fix it yourself you will most likely void your warranty.
