20 Most Recent Apple iPad 32 GB WiFi Tablet PC Questions & Answers
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Apple iPad 32 GB... | Answered Yesterday
When you hold down on the app icon and it shakes with a little x in the left corner, that deletes an app. Once an item is deleted that is it. There is no trash can like on a mac.
Apple iPad 32 GB... | Answered on May 27, 2019
Hi! Well, I'm happy to inform you that there is no trash can on the iPad. Apple is trying hard to simplify the usage as much as they can, hence no trash can to be found.
Hello sir !
Empty Trash Can
In 1982, when Apple created the Apple Lisa user interface, they implemented what they called the Trash can. The trash can is essentially purgatory for files a user no longer wants. Once sent to the trash, the user has the option of restoring the file back to its original place, or annihilating it completely from the computer’s hard drive. Unless there is a backup of a user’s system from before the file was sent to the trash, there is essentially no way of restoring that file once the trash has been emptied.
This metaphor was carried over to Windows 95 in the form of a Recycle Bin. Perched on the desktop of countless millions of averages users was this bin which, when empty, looked empty, and when it contained files, looked full.
There is safety in the Trash Can metaphor. I know that in order to really delete a file from my system, either on Windows or on Mac OS X, I really have to work at it. Yes, there are times when files are accidentally deleted, but for the most part if I realize my mistake before I empty my Trash, I know the file is safe.
All Apple iOS devices such as iPad, iPhone and iPod do not support flash. You will not be able to play any flash based games.
You should check the app store to see if there is an app available for the game you are trying to play.
Apple iPad 32 GB... | Answered on May 26, 2019
You have to reset your iPad. Just follow below steps.
How to unlock iPad without password or how to unlock disabled iPad? It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
itunes-summary-4wdcyutupah1kirb0sfrwsm2-1-0.png For more details, check: How to Unlock iPad without Passcode
Apple iPad 32 GB... | Answered on May 23, 2019
If services are paid: You can edit your Block List by clicking on your Zoosk Screen Name on the top right of Zoosk.com and then click on 'Personals Settings'. Next click on 'Block List' and then on 'Unblock' next to any user that you wish to communicate with again.
Zoosk allows you to browse and start talking to other people for free. However, if you continue to use a free account, you will be able to talk to someone only a few times before your conversations become "locked," meaning you will no longer be able to communicate with your special someone. In order to unlock them, you`ll need to subscribe to Zoosk`s paid services.
Apple iPad 32 GB... | Answered on Sep 20, 2018
Click on your app store app on your ipad then once it opens click on the search button at the button once the search box comes up type in kindle. Then once you find the kindle app click on it and then when prompted for username and password enter them and click download. Hope this helps.
Apple iPad 32 GB... | Answered on Aug 23, 2018
Pogo Games customer service 1-845-582-1921 pogo Customer Service Phone Number 24/7 Customer services online pogo phone number usa
Apple iPad 32 GB... | Answered on Apr 26, 2018
If the creator of this app did not design an iPad interface to address the larger screen the only way you can use this app on the iPad is in iPhone-Display-Mode which is in portrait rotation.
The iPad displays a little (1X) or (2X) button in the lower right corner to switch between zoomed twice and regular view. That is not part of the app.
You can't do anything about this but nicely asked the author of the app to add an iPad interface to his app.
Apple iPad 32 GB... | Answered on Apr 16, 2018
Firstly you have to plug your iPad into Computer and open a iTunes .
After that you can locate a iPad on the left side of the screen and click to the "device" menu .
Then right click on the name of iPad and click to the recover files and select a summary option which is inside a dialog box .
After that place a check mark next to the "Encrypt iPad Backup".
Now you have to enter a password and click to the set Password .
Then plug your iPad into Computer and choose a 'edit" option .
Now you can recover deleted files from Apple iPad.
Apple iPad 32 GB... | Answered on Mar 16, 2018
GT Recovery for Windows Download: www.gtrecovery.net.
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Windows- the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
Hi
I had the same problem, outlook on ipad or syncing ipad with out look is very easy, just follow those few steps, Good luck!!!
I'm using iTunes in order to sync ipad and outlook, make sure your itunes is up to date (help ---->"check for updases") .
How to Use iTunes to syncYour iPad With Outlook Calendar.
* Connect your iPad to your laptop or desktop using the cable that you got with the ipad.
* iTunes will launch in the PC automatically.
* You'll need to find the itunes source list, choose "iPhone" and click on "Info" tab and then "Sync Outlook calendars" option.
* Notice in the lower right corner of your screen the "Apply" button. click on it.
Now your computer is synced with the ipad and the outlook!
Apple iPad 32 GB... | Answered on Mar 01, 2018
First, Plug your iPad into your computer using a iPad charging cable, iTunes will usually by default open, just hide the window,, as well an AUTOPLAY window should open, find where you can see "open folders", click, Windows explorer will show an internal storage image file, double click the internal storage image, you should see a folder called DCIM, double click the DCIM folder. Once open, you should see several folders with funny numbers and letters, they make no sense, but, this is where images that were either, captured by camera or, from the iPad desktop capture feature will be stored, along with any other software that has the ability to capture an image and save it to the camera roll. You can open a folder or select one by clicking once on it, then press CTRL & the letter "?", this selects all the folders, the press CTRL & the letter "C" this will copy all the selected folders, then open your pictures folder, or where ever you'd like the images saved, press CTRL & the letter "P" this will now paste all the folders with the images from your ipad into the location you have selected. Done! Alternately you can sync your iPad, however you must first select the correct setting within iTunes to sync to the correct folder, as well you can turn on iCloud Drive and sync your photo's to the cloud system, which leaves a folder with all the synced images inside the iCloud folder. I hope you have found this information helpful, if you have please leave a positive rating. Good Luck!
Apple iPad 32 GB... | Answered on Nov 27, 2017
The password is normally case sensitive so you make sure that you key in appropriate upper case or lower case if still not working then you have to get back to your employer
Apple iPad 32 GB... | Answered on Nov 19, 2017
If you need to change the iCloud account or Apple ID account on your iPhone, you must delete the existing iCloud account on the device. How to Change iCloud Email on an iPhone
Apple iPad 32 GB... | Answered on May 26, 2017
Using AirPlay in conjunction with an Apple TV connected to your display. Or a special cable the connects to the charging port of your device and your display.
Apple iPad 32 GB... | Answered on May 18, 2017
you should take it to the apple store. If they won't help you, You can try to replace the part yourself, it is available on any auction website. There is an iPad Repair service that can fix it for you, but if you're a little tech savy you should use an iPad repair guide that teaches you how to do the repair yourself.
Apple iPad 32 GB... | Answered on Dec 30, 2016
You will need to restore the device if you cannot remember your password. Just connect the iPad to your computer, open iTunes and select the restore option. Be aware this will erase the data on the iPad, but as far as I know you cannot unlock it without the password.
Hopefully you have a recent backup and then can just put the data back once it's been restored.
Hope that helps!
Apple iPad 32 GB... | Answered on Dec 25, 2016
Apple iPad 32 GB WiFi Tablet PC Logo
912 questions posted
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
iPad Apple
  • iPad Apple
Most Popular Question
club members play pogo game ipad
  • Tablets & eReaders
