20 Most Recent Acer Aspire One PC Notebook Questions & Answers
.swf files are Shock Wave Flash files, which are native to Adobe. Download Adobe Flash Player and you should be able to play them.
Acer Aspire One ... | Answered on Mar 19, 2019
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Acer Aspire One ... | Answered on Mar 10, 2019
you need to install all the software of this Finger Print Reader and update all the drivers or install the driver.good luck
Acer Aspire One ... | Answered on Mar 06, 2019
You can look in your bios if you didn't turn it off by chance.
Otherwise you erase it from your hardware and look for it again in new hardware and install.
Acer Aspire One ... | Answered on Mar 02, 2019
Your computer cannot read your copy of Windows from your 'C:' disk-drive.
You need to purchase a replacement disk-drive, and re-install Windows onto the new disk-drive.
I hope that you have a good backup of all your files!
Acer Aspire One ... | Answered on Jan 06, 2019
The PXE is a component of your computer's network controller.
1) Press the F2 menu on your keyboard and Setup Utility and click the Boot Tab. Press F12 and check the default settings like the IDE 0 and Network Boot.
2) If you do not notice any hard disk drive, it indicates the absence of a hard drive or hard disk failure.
3) Perform factory reset in your computer and you will restore the default settings of your computer.
Acer Aspire One ... | Answered on Dec 31, 2018
Built in web cam? Does the web cam work with the software e.g. - Microsoft life cam? If does not work at all could be out, get an external USB web cam. Could be a driver, could be the site or site settings.
I hope this helps.
Acer Aspire One ... | Answered on Dec 30, 2018
why do you need more memory your machine wont work better
Acer Aspire One ... | Answered on Dec 29, 2018
change boot order to the disc/usb that has the recovery on. don't let it boot from hard drive.
Restart your computer during the boot up process you will see which certain key/s to press to enter set up for a very short time usually the Delete or the F2 key
this will vary depending on your computer
Turn on your Acer Aspire.
Press and hold the "Ctrl" key.
Press and hold the "Alt" key.
Press and hold the "Esc" key.
This key combination will open the BIOS on your Acer Aspire.
hope this helps
hopless, this is.
bitlocker or hdd lockers, hdd encryption was turned on
did you do that or the person sold it used to you did that
if yes, other person only they can unlock that.
or buy new HDD (SSD ,10x better) and start fresh,
buy and OS, install it and run , w7 up, or Linux.
Acer Aspire One ... | Answered on Sep 19, 2018
on acer website search for model number. it is not n214. u will find it on back! something like AODxx AOHxxx
Acer Aspire One ... | Answered on Mar 03, 2018
You should call on 1-800-585-2494 Toll Free at Customer Care and get your help for Acer.
Acer Aspire One ... | Answered on Feb 07, 2018
USB cd-rom's are pretty inexpensive. Here's a page of examples:
https://www.amazon.com/Best-Sellers-Electronics-External-CD-Drives/zgbs/electronics/1292121011
Or you could put a Hirens boot disk on a USB thumb drive and run it. There are articles how to repair that error message. Do a Google search for "NTLDR Missing".
I do not believe there is anything to de-activate! but if your computer rather strangely I would have a professional look at it as it might be compromise.
Acer Aspire One ... | Answered on Feb 05, 2018
well make sure that the drivers are properly installed? go into the device manager to see that the proper drivers are there if not do an update if available for those drivers, seek a professional if you do not know how to go about it.
yes, move out of that humid place! lol, kidding, you might have to get a portable "heater" if that seems to work.
check that the wifi is being managed by Windows and not the application for the wifi, check you wifi settings as well.
Your system will never start without a battery, so forget about that. it sounds like the battery may not be fully seated. Remove and reset the battery. Also, check for the connection pins- make sure none are bent or damaged. Good luck.
Acer Aspire One ... | Answered on Jan 16, 2018
METHOD 1: Reset Corrupt Thumbnail Cache Folder
First of all try to reset thumbnail cache folder so that it starts storing thumbnail cache files from scratch.
1. Press Win+R keys together to launch RUN dialog box, then type following string in RUN box and press Enter:
C:\Users\Username\AppData\Local\Microsoft\Windows\Explorer
Replace Username with your correct Windows user account name.
If the above trick doesn't work for you. Type appdata in RUN dialog box and press Enter. It'll open AppData folder. Now go to "Local\Microsoft\Windows\Explorer" folder.
2. Once you open Explorer folder, select all files/folders present inside it and delete them.
Some files might remain in the folder. Leave them and restart your computer. Now Windows should create thumbnail cache without any problem and it'll not delete them again.
Acer Aspire One ... | Answered on Jan 03, 2018
6,281 questions posted
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire one wont charge u connect
  • Computers & Internet
