There's no paper to unjam?
Misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Model cf3102 display misfeed detected
We get a miss feed on our when we load too much paper. Try loading a little less. To undo a miss feed from overloading it you have to open and close all the drawers and eventually it will go away.
SOURCE: Misfeed detected. I have opened everything I know
there is a piece of paper in the area between the tray 1 and the door. sometimes you can use cardstock to push the paper out. try it
Fusing unit life is over or it can be the paper size problem.if you are using manual by pass tray for A3 printing then make sure machine is detecting A3 in manual by pass tray.if its OK then problem is in fusing unit.
