20 Most Recent
Minolta Di251 All-In-One Printer Questions & Answers
Saya mendapatkan kode CO500 pada
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
A Malfunction was detected.
Please call
Sir, First check the right side cover where the image unit is located. Check the two latches that latch that door are they broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire and that would ruin a perfectly good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
C00500 code what to do
Ispyvolvo, First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Di 251 code c0214
Power Supply, High Voltage Power supply or the Master Control Board, machine on a good surge protector if not after getting these part recommended you get one. Did you have a brown out or a black out. or electrical failure, 1st go with the Power Supply since that feed the other two, then the High Voltage then the Master board, all of this is predicated if you can get these boards the Di251 Series is a Legacy Minolta Series now Konica Minolta, good luck try below web site as a start to find parts
Konica 6501 2721
There is a sensor for the second transfer roller. when the pressure is applied to the transfer roller. That code you have is stating its not doing its job. Recommend a qualified tech look at it. it could also be the High Voltage board #2 is bad. Btw, I’m available to help over the phone in case u need at
Coo10 on my minolta di 2510
Image unit motor failure the image unit is the assemble with the two handles on it inside the machine pull it out and re-seat it. If not the drum or the developer section below it are causing problems. of course the drum motor could also bad worse case is the control board for the motor s bad. Go with the image unit first!!!!! Btw, I’m available to help over the phone in case u need at
