20 Most Recent Konica Minolta Bizhub C451 Printer/scanner/finisher Questions & Answers
2answers
Shows error code c-d261 on startup
How did you solve your problem? I have the same problem
7/2/2020 8:37:48 AM • Konica Minolta... • Answered on Jul 02, 2020
3answers
On startup, it stops at the Konica Minolta display and does not go further to the home screen
The problum is in the sencer in bottom which is durty
3/5/2020 9:29:33 AM • Konica Minolta... • Answered on Mar 05, 2020
Konica print message: Network host '192.168.0.200' is busy; will retry in 20 seconds..
mite be conflict another device may be using that ip address Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/25/2018 4:00:23 PM • Konica Minolta... • Answered on Mar 25, 2018
Bizhub C451 printing black smudges across page
replace the black image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 8:17:47 PM • Konica Minolta... • Answered on Mar 10, 2018
Konicaminolta bizhub c451 no power
Sir/Mam Check your power cord is it plug properly in the wall, power off the machine and disconnect the finisher, document feeder, optional paper draws. Then power on. Power off remove the rear panels any think looked burnt or damaged. Sound like a bad power supply, might want a tech to come out Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 5:12:24 PM • Konica Minolta... • Answered on Mar 10, 2018
Bizhub c451 no power
3/10/2018 5:11:54 PM • Konica Minolta... • Answered on Mar 10, 2018
Error code c3201 for bizhib c451
replace the fusing unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/25/2018 9:34:48 PM • Konica Minolta... • Answered on Feb 25, 2018
Error code C3824
replace the fusing unit reset procedure Sir/Mam, Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/25/2018 9:33:13 PM • Konica Minolta... • Answered on Feb 25, 2018
Bizhub c451
require access to a secure web site Konica Minolta will not allow access to there OS of there copiers not drivers Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2018 6:56:09 PM • Konica Minolta... • Answered on Feb 19, 2018
2answers
Bizhub C451 error C-3924
c7ff0589-2c1c-428b-8214-5be985c427d0.jpgkonica minolta c451 printing problem
1/15/2018 11:54:16 AM • Konica Minolta... • Answered on Jan 15, 2018
P 21 ERROR SOLV THIS PROBLEMS
replace the black image unit and run registration procedure Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
8/10/2017 3:12:53 PM • Konica Minolta... • Answered on Aug 10, 2017
Misfeed detected. Remove paper indicated by 0
misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/11/2017 11:12:33 PM • Konica Minolta... • Answered on Jun 11, 2017
P9 and 921 error in my 451 conika minolta
registration errors replace the black drum and develop unit and also check the transfer belt and Registration sensors Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/11/2017 11:04:51 PM • Konica Minolta... • Answered on Jun 11, 2017
Bizhub c451 with still blue light at start up
if you depress the utility button are all the touch windows there? are there missing ones? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2017 3:18:05 AM • Konica Minolta... • Answered on May 07, 2017
I am facing p21 error in my bizhub c451 pls help me
p21 is stabilization failure. Try and clean the IDC sensors that sit below the transfer belt. also you can initialize and stabilize a few times in service mode as sometimes this can rectify a P21 issue. If all fails then it could be the actual ITB causing the issue
4/3/2017 2:59:04 PM • Konica Minolta... • Answered on Apr 03, 2017
When I make a copy my c451 gives me error c2557
3/12/2017 8:05:30 PM • Konica Minolta... • Answered on Mar 12, 2017
Error code c-fe03 in konica minolta BIZHUB C-451 ?
MFP board issue might have a tech re flash the firmware Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/12/2017 3:48:48 AM • Konica Minolta... • Answered on Mar 12, 2017
Automaticly clean code?
no such thing Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/12/2017 3:45:08 AM • Konica Minolta... • Answered on Mar 12, 2017
Konica Minolta Bizhub C451 Printer/scanner/finisher Logo
Popular Tags
79 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
bizhub c451 still printing only cyan
  • Office Equipment & Supplies
