The
MISFEED Indicator blinks when a
MISFEED has occurred. Remove the
misfed paper referring to the the description of
MISFEED REMOVAL beginning on page 65 of the
pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the
MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper,
you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if
this resolves issue.
Trust
this is helpful. Please vote. :)
