20 Most Recent Konica Minolta Bizhub c203 Copier Questions & Answers
My Bizhub C203 indicates that there is a paper jam at the exit. but i had checked and there is no jam. I also had replaced the fuser unit thinking it will fix the problem but the problem is still the
I have had in the past on these models that when paper is being fed to the exit section the exit rollers are not spinning so paper doesnt get pushed through to the output tray. If this is the case then you will need to replace the exit roller drive motor and possible the PRCB too as sometimes when the motor becomes faulty it knocks out the PRCB ICP chip on the board.
3/9/2021 12:16:08 AM • Konica Minolta... • Answered on Mar 09, 2021
When trying to scan to email from Konica Minolta C203 we get an error message "From Address not set, unable to Transmit, please specify From Address" any ideas.
need to create a from address in the copier either bye at the op panel or thur pagescope look up a you tube video how to set up to scan to email with a bizhub c203 or any bizhub 3 series Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 8:09:21 PM • Konica Minolta... • Answered on Mar 10, 2018
Cual es la cinta de transferencia que tengo que quitar para limpiar los sensores de control de densidad de una bizhub 203
replace the black image unit and clean the transfer belt sensors located under the transfer belt Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 6:18:54 PM • Konica Minolta... • Answered on Mar 10, 2018
P21 appears during warming up, ineo +200
check the registration sensor under the transfer belt which must be removed then slide the cover over the sensors away and clean then one in the rear one in the front or they need to be replaced Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/25/2018 10:54:47 PM • Konica Minolta... • Answered on Feb 25, 2018
C203 bizhub black line 3/4" from bottom of page
what color Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/7/2017 6:40:51 PM • Konica Minolta... • Answered on May 07, 2017
2answers
KM bizhub c 203 prints blank on yellow, I have tried replacing the y imaging unit, y laser unit, image transfer belt, all to no avail. How could it be fixed?
Have you tried the High Voltage board that supply the voltage to the print heads and ITB. could be the print head is fine biut not getting any power to fire the laser and write to the drum
4/7/2017 8:59:51 AM • Konica Minolta... • Answered on Apr 07, 2017
Please how can I clear the memory on my printer (Konica Minolta bizhub C203 coloured printer)
Go to service mode utility-counter-stop-00-stop01 go to system 2/ or 1 select initialization. select all data. press start button restart from main power. Re-configure all network setting for printing/scanning
12/14/2016 1:58:09 PM • Konica Minolta... • Answered on Dec 14, 2016
2answers
Call for servce code c004e
Its a failed Power Supply Cooling Fan Motor. Replace the cooling fan with part number 111T80010.
11/29/2016 8:50:16 AM • Konica Minolta... • Answered on Nov 29, 2016
2answers
Error code c-255a
C255A: Magenta TCR sensor adjustment failure1 Reinstall imaging unit 2 Change imaging unit 3 Change PRCB
10/10/2016 7:17:43 PM • Konica Minolta... • Answered on Oct 10, 2016
How do we properly shake the image unit of the Konica Minolta bizhub c203 to clear error message C-2558?
ugh sorry replace the toner hopper and all of the componets if a new iu dosnt fix the problem
7/21/2016 6:58:44 AM • Konica Minolta... • Answered on Jul 21, 2016
A have paper jammed behind the paper tray on my konicka minolta bizhub c203
remove the draw and remove the paper Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/9/2016 9:43:29 PM • Konica Minolta... • Answered on Jul 09, 2016
Blinking blue light
7/3/2016 7:58:23 PM • Konica Minolta... • Answered on Jul 03, 2016
Mac driver os leopard snow
6/25/2016 4:50:46 PM • Konica Minolta... • Answered on Jun 25, 2016
Konica minolta c203 reboots after power up
power issue or the os has failed, have tech check it out Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/25/2016 2:57:17 AM • Konica Minolta... • Answered on Jun 25, 2016
Bizhub162 dark print
replace the drum Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/18/2016 3:46:00 AM • Konica Minolta... • Answered on Jun 18, 2016
Error code 4553
Yellow LASER is bad, try a reset open close right side door. if it comes back need to have the printhead for yellow replaced Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/18/2016 2:52:04 AM • Konica Minolta... • Answered on Jun 18, 2016
WHAT DO YOU DO WHEN YOU'RE SCANNING AND IT IS FAILED TO COMPLETE JOB AND YOU SHOULD CHECK LOG?
on the control panel screen is section for you to check the status of print/scan items. you will be sent to a screen you select the job and check details, if this was a scan to email might check the mail server if scan to pc check folder to scan to is a shared folder Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/18/2016 2:47:09 AM • Konica Minolta... • Answered on Jun 18, 2016
What is a service code c2558 mean on my copier?
C2558: Abnormally high toner density detected black TCR sensor
Reinstall toner cartridge
Change imaging unit/K
Change PRCB
6/9/2016 7:47:19 AM • Konica Minolta... • Answered on Jun 09, 2016
Error codesc4151
The print head (LASER) under the cyan image unit is bad Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/15/2016 9:54:35 PM • Konica Minolta... • Answered on May 15, 2016
Konica Minolta Bizhub c203 Copier Logo
208 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
copies very dark
  • Office Equipment & Supplies
