SOURCE: Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
SOURCE: canon pixma MP620 paper jam
Hello! I have solved your problem! The first thing you need to do is extend the back paper holder all the way up. This should uncover a long rectangular hole. There is a plastic piece with 2 arrows pointing to the right on it (if you are looking at the back straight on). Simply push them to the Right and it will pop up on the Left side. You can now lift that piece out and VOILA there is your misfed paper! Just reinsert the rectangular piece back in after you have taken the misfed paper out! -Gary Maples
SOURCE: Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
SOURCE: Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
SOURCE: My Canon PIXMA Pro9000 InkJet Photo Printer paper jam error
Had the same problem with mine. Shook it upside down and cleaned it with air cans after reading this solution for other canon printers:
http://www.fixya.com/support/t119769-false_paper_jam_warning_canon_pixma
To my surprise, it worked perfectly... and was great stress relief.
