Computers & Internet Logo
Posted on Apr 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
It does no start. gives one long beep
  • il14artigian Apr 23, 2009
    it gives one long beep, space, long beep, space, long beep......
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3971
Points
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
  • Anonymous Dec 15, 2012
Anonymous
Level 2:
  • Expert 66 Answers
  • Posted on Apr 23, 2009
Anonymous
Expert
Level 2:
Answers
66
Questions
Helped
24144
Points
184
You have to tell me how many beep your system is giving . u just said that one long beep (2-3 sec) than agian beep.but after 2 or 3 sec is it short beep again or long beep and how many. i am giving you solution if it didnt solve your problem friend than you have to tell me how many and what type short or long your motherboard is giving.
your system is giving post errors means audio beeps error.i am giving you some of the common post errors according to beeps.
1 long beep (space) 2 short beeps or 1 long (space) 3 short beeps  : means that video system failure moniter is dead or unattached.check your moniter connectons or replace moniter or if u have a builtin video card than u have to check it also because this error beep means that there is some problem with your display whether it is moniter or display card.
1 long beep (space) 3 short beeps (space) 3 short beeps (space) 1 long beep : means RAM FAULTY you have to replace your motherboard RAM
i hope that it help . THANKS
Martin ONeill
Level 1:
  • Posted on Nov 30, 2013
Martin ONeill
Contributor
Level 1:
Answers
Questions
0
Helped
3971
Points
0
Same problem. Removing memory, and trying them one at a time worked. Thank you.
2 Related Answers
jomabug76
Josh Whitehead
  • 1148 Answers
  • Posted on Oct 05, 2008
SOURCE: Motherboard
TAKE YOUR DDR CARDS OUT ,, AND SWITCH THEM,, ,,IF THAT DOESNT WORK TRY WITH ONE AT A TIME,, GOOD LUCK
Anonymous
  • 158 Answers
  • Posted on Oct 07, 2008
SOURCE: Motherboard
check
  • Power supply,
  • system board,
  • keyboard
  • Display adapter (MDA, CGA)
for continous beep
House alarm beeps every 45 seconds
Not knowing what brand makes it tough, most of the time if you push any key it should silence it.
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
3helpful
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
How do i change outgoing answer phone message
Solution for Fax1360, if this does not work please let me know as this process should be the same.
Recording an outgoing message (OGM) on an external TAD 7
Timing is important in recording this message. The message sets up the ways to handle both manual and automatic fax reception.
a Record 5 seconds of silence at the beginning of your message. (This allows your machine time to listen for the fax CNG tones of automatic transmissions before they stop.)
b Limit your speaking to 20 seconds.
c End your 20-second message by giving your Fax Receive Code for people sending manual faxes. For example: 'After the beep, leave a message or send a fax by pressing *5 1 and Start.'
Recommendation: recommend beginning your OGM with an initial 5-second silence because the machine cannot hear fax tones over a resonant or loud voice. You may try omitting this pause, but if your machine has trouble receiving, then you must rerecord the OGM to include it.
Christy
Cant load the os
your mobo might be broken. Try to uptate or recover bios. it can be done when changing jumpers on mobo. read mobo book for excat settings
2answers
Motherboard
2answers
CDA CW 446 dishwasher problem
Emma:
Is there a reset button on it? If so, press that. There are also sequences of buttons which one has to push to reset it. These are kept secret. Try pressing Hi Temp and Heated Dry, turn loose and press again within Five seconds. Or turn off the electricity and see if that resets it
May 11, 2008 • Dishwashers
1helpful
Packard Bell error signals
here is a list of packard bell beep codes with meanings
http://www.uktsupport.co.uk/pb/mb/phnxcode.htm
Hope it helps you
Grand Canyon Tech
Grand Canyon Tech
