20 Most Recent
Honeywell Ademco 6160 Alpha Keypad Vista 15p, 20p Questions & Answers
FC flashing on never monitored unit
what you are looking at is a fail to communicate over the phone the panel needs to see a true analog phone line to communicate
most phones are digital phone now a days it is hit and miss with this form of communication some times it works sometimes it dosent i would suggest adding a gsm communicator for if it is digital there is a chance of it not dialing out over a digital phone line If you need further help, reach me via phone at
https://www.6ya.com/expert/joshua_f823c77053c73844
Alarm started beeping and displayed BF check on
BF error on keypad is for Failure of Backup Communications. Usually for cell backup. If it is a monitored system, call your monitoring company. If not monitored, either call a service tech to repair it or if you have the programming code, you can turn the feature off in programming. Best to have a professional do it though.
If you have had any phone changes since it was installed, that may be a lead to where the problem is. Especially, if it is no longer monitored. BF basically means there is a problem when the system attempts to dial out to the central station on the backup setup. Again, this can be disable in programming if you no longer need it.
Vista 20p can't set time
Did this come with the manual for the keypad. You can go on line to honeywell or call them and ask for tech support.
Ed
What is a long range radio trouble
It indicates a problem with your cellular radio or that your alarm system is programmed to look for one that is no longer working or connected to your system. This can be disabled in installer level programming.
Trying to get installer code on Honeywell Vista 15-P
hit *20 then put in whatever 4 digits you want as installer code. write this down on your program sheet for future reference. yes, you should have a program record sheet to follow and know how to navigate in programming or else you could make things worse.
Key pad BAT
replace main system battery. this will either be a 12volt/4ah battery or a 12volt/7ah battery.
