20 Most Recent EliteGroup P4VMM2 Motherboard Questions & Answers
Mother board
have u checked the power supply and all of its connections and the system board fan to make sure they are operatring correctly and also is the beep code a straight 5 beeps or is sthere any thing else kplease let me know so i can try to give you some more help
8/16/2016 7:46:13 AM • EliteGroup... • Answered on Aug 16, 2016
2answers
3 long beeps no video
Hello, Check your RAM, or Change your system RAM. Thanks Tony
6/24/2015 6:46:32 PM • EliteGroup... • Answered on Jun 24, 2015
With which button do i reach safe mode
During the boot process you will press F8 to bring up the safe mode menu. You want to press F8 after the computer posts and just before the windows screen comes up. Also you cannot press F8 too many times so when in doubt just keep pressing F8 after you turn the computer on until the menu comes up. This is what you should see if you have successfully pressed F8. 0cd58368-a115-4858-a4e4-27cb57d569a2.jpg If you need further help, I’m available over the phone at https://www.6ya.com/expert/benjamin_29adbb94bfb43281
10/1/2014 1:14:09 PM • EliteGroup... • Answered on Oct 01, 2014
H;95.1khz v;59.8hz
Go into Safe mode. Delete video drivers, then scan for changes.
4/6/2014 3:24:45 AM • EliteGroup... • Answered on Apr 06, 2014
Pxe-E61 media test failure
Means the network cable is missing, or the onboard NIC device/cable setup is broken.
11/8/2013 1:56:22 PM • EliteGroup... • Answered on Nov 08, 2013
0answers
Manual pdf
Be the first to answer 10/17/2013 12:53:57 PM • EliteGroup... • Posted on Oct 17, 2013Be the first to answer
0answers
User manual
Be the first to answer 10/14/2013 3:45:08 AM • EliteGroup... • Posted on Oct 14, 2013Be the first to answer
0answers
DH61H0 motherboard graphics driver problem
i have a dh61ho intel board when i installed grapfics driver its restrted autometically i have to uninstall it then only its work i unable to play video and games plz help
6/3/2013 7:01:36 AM • EliteGroup... • Answered on Jun 03, 2013
Manual http
Is it plugged in? Is there power to it? Is the computer switched on? Is the computer connected to the monitor? If you give details of the problem, you will get a helpful answer.
5/9/2013 3:47:39 PM • EliteGroup... • Answered on May 09, 2013
What is compabible memory and processor on P4VMM2 elitegroup motherboard
Hi lemonlarosav: I make this video for help ...wish you solve your problem
1/11/2013 7:13:32 AM • EliteGroup... • Answered on Jan 11, 2013
3answers
Cant connect to internet
Hi ianzky, If the PC with the ECS P4VMM2 motherboard is connected to a network with a hub or router check if you can see the other PCs assuming their sharing is turned on. If yes then it is possible that you have to simply set the IP Add, Subnet, specially the Internet gateway and DNS in your IP/Networking configuration of the P4VMM2 PC assuming you want to manually install these numbers and not to Auto Obtain. Just make sure you follow the numbers of the other PCs except for the last digit(s) of the P4VMM2 PC IP Add. If you can not see the other PCs in your network, then it is possible that your lan cable is defective, try checking if the lights in your hub/router and/or at the back of your lan card lits up when you plug your cable both ends. If yes then it is good if not you have to replace your cable. Since you installed a new LAN card, I will assume that you have checked if the drivers are installed in the Device Manager and there are no conflicts or yellow mark(s). Both versions of the ECS P4VMM2 (7.3 & 8.1) have built-in LAN, if you want to continue using the new lan card it might help conserve resources if you disable the built-in lan in your bios or use the original built-in lan instead and reconfigure. In Win XP, try uninstalling the lan in Device Manager, on reboot it will be auto reinstalled and you can manually configure again. If by a remote chance that you are using 98SE, try checking your root file MSDOS.sys and see if there is an entry that say Network=0, change it to 1. I doubt if the motherboard is defective since you already tried installing a new lan card. Good luck. Pls post again how things turn up. Kind regards.
11/7/2012 3:29:29 AM • EliteGroup... • Answered on Nov 07, 2012
2answers
Connection of Casing built in Input Leads to PCB
The manual for the MB will have a diagram. Google for the manual if you don't have it.
9/9/2012 4:55:59 PM • EliteGroup... • Answered on Sep 09, 2012
No screen display
First of all see POST screen is visible or not if yes then second see OS booting screen is visible, with this you can judge the problem is with Motherboard/Memory or OS.
8/24/2012 3:35:34 PM • EliteGroup... • Answered on Aug 24, 2012
EliteGroup P4VMM2 Motherboard Logo
343 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
compabible memory processor p4vmm2
  • Computers & Internet
