20 Most Recent Kidde Nighthawk Combo Gas/co Detector Questions & Answers
My gas alarm went off
Slightly possible. The wine would have had to be within a foot or less of the detector.
3/27/2024 2:35:42 PM • Kidde Nighthawk... • Answered on Mar 27, 2024
11answers
Carbon monoxide detector err code
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (It's not worth to buy just a sensor). Take a look on amazon: Amazon com Carbon monoxide detector (watch out on reviews). I hope this was helpful. cheers
12/23/2020 2:47:41 AM • Kidde Nighthawk... • Answered on Dec 23, 2020
How can i shut off my kidde carbon monoxide detector, it is a constant alarm unless you remove the battery completely
Try another hard whack. If that does not undo the initial damage, nada will and you have a nice paper weight.
9/1/2017 12:50:10 PM • Kidde Nighthawk... • Answered on Sep 01, 2017
Hi, I have two
Carbon monoxide detectors have a fixed life span. You did not post the model number and there is no way to tell how long it ago it or the parts in it, were made.
3/18/2017 4:24:41 PM • Kidde Nighthawk... • Answered on Mar 18, 2017
Will low battery cause nighthawk explosive gas alarm to trigger
certainly will -- same as low battery will set of the smoke alarm
5/24/2015 4:15:48 AM • Kidde Nighthawk... • Answered on May 24, 2015
I have model kn-cob-lcb-ca...it does
send the detector back and have it replaced, The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm. • Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
4/24/2015 6:46:43 PM • Kidde Nighthawk... • Answered on Apr 24, 2015
2answers
Single continuous beep of co
CONNECT THE UNIT OUTDOOR UNDER CLEAN AIR IF IT PERSIST, REPLACE THE UNIT.
10/24/2014 7:32:44 PM • Kidde Nighthawk... • Answered on Oct 24, 2014
2answers
I have a kidde/nighthawk model#kn-cosm-b. We
Constant problems with these combo detectors. My best suggestion is unplug it from the wall, remove the battery, leave the battery compartment open, then using a can of compressed air that has a straw nozzle (like you clean your computer with) blow the dust and lint out of the unit. Pay particular attention to the grill vents on the front. When doing all of this, hold the can of compressed air as upright as possible. Replace the battery and plug it back into the wall receptacle.
Hopefully, that will clear up the problem. and accumulation of dust and lint will cause them to false at times.
Pressing and holding the test button for 5 seconds is "supposed" to reset the detector.
10/8/2014 8:05:33 PM • Kidde Nighthawk... • Answered on Oct 08, 2014
What does err mean on carbon monoixide dectectors
Is it about 7 years old? The chemistry of the sensor is only good for 7 years, so by regulation they are required to have a timer that makes them die at 7 years, after which they are no longer accurate and could mislead you into a fatal CO poisoning. I presume you've already tried replacing the battery.
7/8/2014 6:30:57 AM • Kidde Nighthawk... • Answered on Jul 08, 2014
0answers
Kidde Nighthawk Combo Gas/co Detector Logo
380 questions posted
Top Kidde Home Security Experts
 Mikey
Mikey
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
View Most Popular
Kidde Home Security
  • Kidde Home Security
Most Popular Question
err mean carbon monoixide dectectors
  • Home Security
