I loaded the envelopes into # 1 and selected that tray when I created the envelop using WORD. I also selected a custom design and envelop as the printer setting. Now I can not print it for I get an error message that says I needed to load the correct paper size into tray #1.
First recommended that you use the bypass tray on the right side, also before placing the envelope in the bypass tray send the print job over first, the screen will say replenish paper then go ahead and place the envelope on the tray. and let it take it or hit the start button Ensure you select #10 commercial media and bypass tray in your print driver preferences. May also want to have tech come out and look at the tray and run MAX and Min. Adjustments.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Bizhub 200 printing custome envelopes
Do not know if this helps, but I could not print Com 10 envelops until I said the type was "normal" - Type "envelope" would tell me I had the wrong size.
SOURCE: printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
SOURCE: I cannot figure out how to print envelopes on my
Chances are your print drivers haven't fully recognized the configuration on your copier/printer.
Click on 'Start', then 'Printers and Faxes' (I'm assuming you're using XP), then find the icon for the bizhub printer. Highlight it, then right-click over it and choose 'properties' at the bottom of the list.
In the window that pops up go to 'printer preferences' and it should launch another pop-up window. Look within the tabs that appear for a button that says 'auto detect' or 'auto configuration' and click on that. Then hit 'apply' at the bottom of the window.
This will allow the print drivers to fully recognize the configuration of your copier/printer, and you should then be able to use the bypass tray. Make sure the paper in the tray matches the paper you're choosing in the print job.
Testimonial: "I couldn't find the auto detec or auto configuration button/tab within the properties?"
For details about how to load an envelope into the printer, see
the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear
tray, orient the envelope so that the flap is on the left and the folded surface
is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the
Main tab.
4. Click the Page
Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape
for Orientation.
6. Click OK.
When you execute print, the information is printed on the
envelope.
