20 Most Recent Minolta bizhub 200 All-In-One Printer Questions & Answers
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta bizhub... | Answered on Sep 11, 2019
Please explain (Stating (!) memory Free 99 0/0????????
Minolta bizhub... | Answered on Feb 18, 2019
Error cod C4101
Machine Konica Minolta c6500
Minolta bizhub... | Answered on Sep 08, 2018
need a new one
Minolta bizhub... | Answered on Mar 12, 2017
Fault Code
C5351
Description
Power Supply Cooling Fan Motor Failure
- The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning.
- The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Remedy
1 Check the M4 connectors for proper connection, and correct as necessary. 2 Check the fan for possible overload, and correct as necessary. 3 M4 operation check PWB-A PJ33A-1 (REM) D-5 4 Change PU1.
Minolta bizhub... | Answered on Oct 28, 2016
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Minolta bizhub... | Answered on Apr 14, 2016
Fuser code. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is cover next where you connect the Ethernet cable. Remove the cover with machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you the screen with copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
Minolta bizhub... | Answered on Nov 01, 2015
Check the network connection, SMTP Mail server, email address sending to and Network IP address and subnet.
Minolta bizhub... | Answered on Oct 31, 2015
Have you check its manual particularly its features, does the unit capable on touch screen mode, or may be you need to set some settings to enable touch screen mode..
Minolta bizhub... | Answered on Jun 05, 2015
Replace the developer. If that does not work replace the ATDC sensor located under the image unit. Has multi-color ribbon cable. If not that then the main control board. Best bet would be replace the developer and ensure you clear the counter for develop and run the F8 process after replacing the developer. DO NOT USE A VACCUM CLEANER to replace the developer because the static electricity from the vacuum cleaner can destroy the sensor. Also the copier uses the counters to adjust voltages for certain assy. so if you replace the developer and don't clear the counters then the machine will adjust voltages for a used drum or developer when in reality the developer or the drum are new. Causing image problems and codes such as 2257. Also recommend the drum and cleaning blade be replaced, does the control panel in the upper left say replace the PC drum?
Try this site for the parts:
T
Try this site for the partsT Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Minolta bizhub... | Answered on Mar 01, 2015
looking in the service manual could not find the code.
Minolta bizhub... | Answered on Feb 22, 2015
could not find that code could it be 8301?
Minolta bizhub... | Answered on Feb 21, 2015
per the following question have a tech do it it is not easy
Minolta bizhub... | Answered on Feb 20, 2015
AS your pervious question follow that
Recommended that allow only KonicaMinolta tech do it, you must replace the developer, drum cleaning blade, Developing unit and run the required F8. AND THE COUNTERS MUST BE CLEARED FIRST BEFORE REMOVING OLD UNIT.
are you only on that scan can other scan to their computer? If so your computer is the problem check that folder scanning to is a shared folder
Minolta bizhub... | Answered on Feb 19, 2015
Utility/Counter Details Stop00 Stop02 Maintenance Mode then touch screen adjust does not work get a new control panel try web site below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Minolta bizhub... | Answered on Feb 18, 2015
Minolta bizhub 200 All-In-One Printer Logo
106 questions posted
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
error message c5351 mean konica minolta
  • Office Equipment & Supplies
